What are my chances?
Old Aug 24, 2002 | 04:36 PM
lil305gta's Avatar
Cool What are my chances?
A conv CamaroZ28 with a 355 tpi, heddman headers, 58mm tb, 3.73 gears, open 2 1/4 inch exhaust, gutted air boxes against my ride, check out my sig. Don't know if he's bluffing about the 355. Eigth VIN # is F. What are my chances, about to install 3.45 gear and port plenum.
1990 Trans Am GTA 305 TPI-SLP Tranny Rebuild Kit w/ Mechanical Diode,Vette Servo, Transgo Shift Kit, Stock Vette Converter. Flowmaster Exhaust, Edlebrock Headers, 3 nch Dynomax Hi-flo Converter, K&N Cone Filter, TB Airfoil. Taylor Spiro 8mm Wires and Bosch Platinums. Pioneer DEH 4300, Audio control 24XS, PPI 500IQX and 200IQX Sedona Amps, 15 inch Kicker XPL Subs, and Kicker 4x6/6x9.
Old Aug 24, 2002 | 11:12 PM
irocbob89's Avatar
Post
the race would be close in a way. If you port your plenum and port it alot you MIGHT have a chance. The more the better, but you also have a 305. A 355 is a 350 bored .30 over. Nothing more then an overhaul. I think hes got you beet though. You have a 305 with the same bolt ons he hast to his 355. Plus you have all that stereo equipment witch adds weight. He also has a convertable witch adds weight to his car to but im not sure man, like i said it would be close but i think he will take you.
89' red Iroc-z
386 stroker
Mini ram, 58mm tb
30#lbs,255 high flow fuel pump
slp cam, 1.6rr
edelbrock performer heads p+p 2.02 1.60
Hooker super comps, Mufflex 4' exhaust
Ford 9' 4.11 gears, detroit locker, 31 spline
Full suspension
B&M mega shifter,2800 stall
baer rear brakes,line lock
converted to speed density
Ed Wright dyno tuned
89' red Iroc-z
LT-1, 4L60E
free mods,chip,no cat, flowmaster
[This message has been edited by irocbob89 (edited August 25, 2002).]
Old Aug 25, 2002 | 01:02 AM
Z28ROC's Avatar
Post
If he really has a 355. Then chances are he's probably got a nice cam and maybe head work. Cause since you said, his car came from the factory with an LB9. Now we're talking engine swap. And why would someone go to the trouble without making it pack a punch?
Mario,
White 94 Z28
Yeah I got a few mods
Video
Black 87 IROC-Z
Old Aug 26, 2002 | 12:43 AM
PLANT PROTECTION's Avatar
Post
Don't race for money. Your 305 may run with a L98 without your system and his 355 would beat an L98(assuming the norm). His 355 will be slow if he has a bone stock TPI on it, but still faster than yours.
1989 Formula 350
Old Aug 28, 2002 | 02:12 AM
lil305gta's Avatar
Post
So after I install my suspension parts- shocks, struts, poly bushing kit, ported plenum, hypertech chip,fresh tune up, no stereo equipment and 3.42 gears...would I fair pretty well.
Old Aug 28, 2002 | 10:08 AM
Ucantcme57's Avatar
Post
Not counting the stero equipment convertible and coupe Camaro or alike weigh vertually the same. Convertibles were compact and they didn't have the hatch or the glass in the rear. Go over to Thirdgen.org and watch that motor week movie from 86. Even in there the talk about the similar weights.. I wouldn't race for money.. He's got you beat.
86 Chevrolet Camaro Iroc Z-28 Fully Loaded With T-Tops
Mods;
Spohn SubFrame Connectors, S&W Race Car Chassis 8 point Roll Cage, 1997 SS Aniversary 3.42 POSI Rear End with 12" Rotors and 4 Piston PBR Calipers, Balanced Drive shaft... Others soon to come...
Best times before any mods done, Complety Stock;15.6 @ 87mph
Waiting for the tracks to open again to see what I got going on Now!
ntimad8.cz28.com
SergheiS
Sep 29, 2015 08:56 PM
Bxlt1
Sep 10, 2015 08:16 AM
michaelzilinski
Jul 31, 2015 08:41 AM
Boss002
Jul 24, 2015 10:47 AM
Boss002
Jul 9, 2015 03:33 PM
