Need some advice bad...
Old Aug 23, 2002 | 04:42 PM
bigdave8301's Avatar
Arrow Need some advice bad...
Hey, I've got an '89 Firebird Formula 350 TPI, 5.7L with the WS6 package, and I need some advice. Right now I'm working on restoring the interior, but I need to make it as fast as it can be real cheap-like. It's already got the Performance chip (wow...), a K&N filter (yet again, wow...), a B&M shift kit, a local exhaust jobby with a cheap muffler and duals (not true duals), and the car came factory with 3.42s. I'm going to put headers on it soon, but what else should I do to decrease my times at the strip? I'd like to avoid computer work, but if there's no other way then I don't have a choice. I need to know how to get the most bang for my buck outta the old 'bird. Any reply at all would be helpful. And do the dual cats really matter? Because it's still got 'em and right now I'm dragging on everything and I'd love to cut those babies off and re-run my exhaust.
Old Aug 23, 2002 | 05:46 PM
CoOrAzY82z's Avatar
Post
Depending on where you live , but id cut those suckers off I live in oklahoma so we dont have inspections stickers but everyone does it makes a little bit louder but its does make a lil diffrence for the 30 buck to get it done at a muffler shop
Old Aug 23, 2002 | 05:53 PM
IROC5.7TPI's Avatar
Post
The best and cheapest mods arethe following in no particular order:
1) Advance base timing to 10* advanced.
2) Clean the throttle body and plenum thoroughly with carb cleaner thats O2 sensor safe.
3) Replace the O2 sensor, spark plugs, wires, cap, rotor, fuel filter, air filter (or maintain the K&N if applicable).
4) Open up the airbox by cutting holes in it if thats not already been done.
5) Get a 2500 stall speed converter.
6) get sticky DOT legal tires for the back.
7) Get headers and a full 3" cat back exhaust system with a good hi flow muffler.
8) Do cam and heads and intake mods.
9) Burn new EPROM.
10) Install subframe connectors
11) Install boxed lower control arms.
12) Lighten the car. Remove back seat, spare tire and jack, etc.
Hope this helps some. With a little work that car should be in the 13's with little basic mods.
Mike L.
1987 IROC Z 5.7 TPI A4 3.27 Borg-Warner four wheel disc
Mods:
2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified airbox w/ K&N's, Relocated MAT sensor, Gutted MAF, 160* thermostat, MSD 6A, Accel 8mm Wires, bypassed TB coolant, 3" Flowmaster 3 chamber single outlet, custom adjustable cutout, 3" MAC mandrel intermediate, airfoil, ported plenum. !smog, Crane AFPR, Accel rail mounted FP gauge, Harlan shiftlite, 24lb. injectors, Hedman headers, a few others I forgot...??? FINALLY GOT PAINT!!
Check out my IROC webpage!
Old Aug 23, 2002 | 05:57 PM
CoOrAzY82z's Avatar
Post
Old Aug 23, 2002 | 06:10 PM
CoOrAzY82z's Avatar
Post
Old Aug 24, 2002 | 02:55 PM
IROC5.7TPI's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by CoOrAzY82z:
Depending on where you live , but id cut those suckers off I live in oklahoma so we dont have inspections stickers but everyone does it makes a little bit louder but its does make a lil diffrence for the 30 buck to get it done at a muffler shop</font>
I agree 100%. Almost forgot to mention that mod. Just one thing CoOrAzY82z- yer stutterin'
Mike L.
Mods:
Jeff1904
Jun 5, 2016 05:00 PM
David Dempsey
Mar 12, 2016 12:42 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
