help!!! installing manual steering box
Old Aug 6, 2002 | 09:40 PM
1SLOSBC's Avatar
Post help!!! installing manual steering box
ok guys/gals...i am putting in a manual box from a s-10 in my car....any hints, tips, or a site that might give pics...
anything would do right now....just to get a start
thank you
88 z28 385ci stroker....monster tire shredder w/custom TH350 T5-6 speed automatic. ss hood. 4th gen seats. centerline telstars. so custom, yet so factory.
Old Aug 6, 2002 | 11:33 PM
IrocSS85's Avatar
Thumbs up
well I like mine.
should bolt right in. nothing to do. I originally installed the truck pitman arm w/it, but thats too long and too many turns lock to lock. so I installed the orig. camaro pitman arm. still needs to be turned alot compared to the iroc box, but that doesnt matter to me. I like going straight.
chris
Old Aug 6, 2002 | 11:42 PM
1SLOSBC's Avatar
Post
HOW MANY TURNS FROM LOCK TO LOCK??
MINE NOW IS ONLY 2 3/4...VERY RESPONSIVE
ALSO, I RUN SKINNY'S UP FRONT...BUT OCCASIONALLY RUN THE 16X8 IROCS FOR LONG TRIPS....
HOW HARD IS IT TO STEER...I HEAR ITS A BREEZE???
Old Aug 6, 2002 | 11:45 PM
Stephen 87 IROC's Avatar
Post
Unbolt the power steering box and everything related to it and throw it away. Bolt the manual box on. You should use the f-body pitman arm though.
Metric tools will be needed as well as a pitman arm puller. It's been a while since I installed mine. I think the 3 bolts that hold the steering box onto the frame are 18mm. The bolt that holds the bottom of the steering shaft to the input shaft is 10mm.
I never counted lock to lock. I don't like turning that sharp anyway. The spool in the diff makes it hard on tires.
Driving down the road isn't bad. You won't like the wide front tires when trying to park in a parking lot.
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.589
Best MPH on a time slip: 116
Best corrected ET: 11.079
Altitude corrected rear wheel HP: 468
Best 60 foot: 1.617
Member of the Calgary Drag Racing Association
[This message has been edited by Stephen 87 IROC (edited August 07, 2002).]
Old Aug 6, 2002 | 11:56 PM
1SLOSBC's Avatar
Post
SO...WITH SKINNYS ON THE FRONT...HOW DOES IT COMPARE WITH POWER AND W/O POWER STEERING?
IS IT HADRER TO TURN??
I KNOW I BYPASSED MY PUMP ONE TIME AT THE TRACK AND IT WAS ALMOST IMPOSSIBLE TO TURN THE WHEEL...
IS THE MANUAL BOX GOING TO BE LIKE THIS?
Old Aug 7, 2002 | 08:41 AM
firechicken_3's Avatar
Post
not gonna be the same as bypassing the pump, if you just took the belt off, or linked the hoses, you still had all the hydrualic fluid to work against, with a manual box you won't have that,
i drove an s-10, its alot of turns lock to lock, and the steering really wasn't that heavy with 215/70/15 that it had on it, but remember that truck had a 4cylinder in it, and the truck in general is lighter than nour cars, so front axle weight is considerably less
84' Firebird, 305ci lg4, 700R4, 288/292 duration .450/.460 lift,Edelbrock Performer intake, Holley 600cfm 4 barrel, K&N filter, Pacesetter Headers, 3'single exhuast, dual out muffler, no cat,Motive 3.73's and Auburn Posi
1/4mile 15.17sec @ 92.5mph
currently in pieces, for manual swap
Old Aug 7, 2002 | 10:23 PM
Post
You're not going to be able to sit still and spin the wheel around with one finger. It will require a bit of hand over hand action at very low speeds.
I have no problems driving around the pits. Even turning to pull into my pit spot isn't that bad. I have more trouble with the transbrake button installed in the steering wheel getting in the way.
Don't get a steering wheel that's smaller than stock. Manual steering vehicles usually have a larger steering wheel to give extra leverage while turning the sheel.
My race car has a smaller wheel but there are very few corners I have to worry about.
The only way you can bypass the pump with power steering is to loop the inlet and return lines together. Even then it's not the same as a manual box.
Old Aug 8, 2002 | 10:22 PM
1SLOSBC's Avatar
Post
thats what i was wondering , ive taken off the belt and looped the hose.....and it sucked....im gonna put the box in and see what happens...should be in by sunday night if i get the chance
any info..please reply..
thanks guys
Old Aug 9, 2002 | 12:05 AM
88 427 Camaro's Avatar
Post
I installed a manual box about 3 years ago and IIRC, it's ~ 4turns lock to lock. It's much better than a power box looped off, but like Stephen said, it's not finger steering either. The only time it needs some muscle is at parking lot speeds and even then it's not too bad.
I used the Camaro pitman arm. I also had to hammer the frame rail a little to get the box to mount flush.
Miles
88 427 BBC Camaro
7.76 @ 94 (1/8 mile) 10/01
12.18 @ 113 (1/4 mile) 10/99
I have brand new series 3 9 bolt posi carriers and gear sets to 4.10 available for borg warner 9 bolts. Check my web page for more info.
http://www.koolmeister.com
Old Aug 9, 2002 | 05:20 AM
Cam28_boy's Avatar
Question
Is there a specific year that the manual box is coming from? This sounds like a nice way to get a couple of easy hp.
Old Aug 9, 2002 | 09:38 AM
Post
85-90 s10's for sure. Probably others too.
Miles
88 427 BBC Camaro
Airplanedoc
Feb 1, 2015 07:14 PM
CaRParts102
Dec 6, 2014 08:45 AM
ro2207
Dec 4, 2014 06:18 PM
Jul 4, 2005 05:00 PM
