Help!! Bad hesitation @3000rpms in 1st gear
Old Aug 19, 2002 | 12:10 AM
formul8's Avatar
Question Help!! Bad hesitation @3000rpms in 1st gear
This is an L98 in a friend 's 1988 Corvette I'm modding for him.
He has a 3.73 gear,stock trans&converter, stock motor,just some minor free mods.
From a dead stop, it pulls like crazy to 3,000rpm and then has a bad hesitation and then starts pulling to 5000rpms.
We just did plugs and wires,ported the plenum,AFPR and t/b bypass. It started this before any of these mods.
I have no clue what could cause this?
Old Aug 19, 2002 | 09:18 AM
1989gta's Avatar
Post
So does the power come back at certain rpm? If not and it hesitates you may want to check the injectors with an ohm meter. They should all be really close in resitance. Also check the volate of your tps.
Old Aug 19, 2002 | 09:39 AM
formul8's Avatar
Post
The weird thing is it only does this in 1st gear. The power comes back full on after it recovers from the stumble.
Feffman
Oct 9, 2015 05:42 AM
IRABuss
Sep 7, 2011 09:08 PM
KASR_Z28
Aug 6, 2002 03:34 PM
simple
Aug 2, 2002 03:30 PM
