Timing
Old Aug 9, 2002 | 11:16 AM
Bristol's Avatar
Post Timing
I have a 355cid motor with hyperutectic pistons. What kind of timing can I run. I have it at 8* now and the new motor is broken in and am ready to go all out.
Old Aug 9, 2002 | 11:28 AM
irocz383's Avatar
Post
Man, no-one ever replies to a topic about timing. I've tried a number of times and they alwayse say "start at 8 and work your way up until you find the best improvement without detinating"
I could have figufred that out myself, right!??!
Anyway, I think 12 is about as much as you'd want to go. It may even be a little too high. Its hard to say cause those pistons are still fairly new on the market.
BTW... I would love to see your car. Since your in Richmond we should meet sometime.
Old Aug 9, 2002 | 11:36 AM
firechicken_3's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by irocz305:
</font>
the reason people say that is because thats what you have to do with a modified car, since every engine is a little different, you can only give some one a resonable starting point, if someone said, everybody set your timing at exactly 9 degrees, there would be alot of angry people, cuz there cars would run like $hit,
you gotta use your ears, and eyes, and other senses to tune a car, not a book, it can merely give suggestions, an old motor head friend that has been there and done it before, can be alot of help,
personally my car has considerably more base timing than 12 , i can't remember what it is, nor can i check because its currently sitting on a stand
84' Firebird, 305ci lg4, 700R4, 288/292 duration .450/.460 lift,Edelbrock Performer intake, Holley 600cfm 4 barrel, K&N filter, Pacesetter Headers, 3'single exhuast, dual out muffler, no cat,Motive 3.73's and Auburn Posi
1/4mile 15.17sec @ 92.5mph
currently in pieces, for manual swap
Old Aug 9, 2002 | 11:57 AM
Bristol's Avatar
Post
Hey IROC305 lets do it. Always ready to see a fellow F-body with new ideas. Hey what exhaust are you running? I asked in the AFPR post but I guess you didnt see it. I saw you leave Blockbuster and your car sounded sweet. I actually just met another guy with a 1991 white Z28 with a 305 5speed 1LE R7U. Yes the Players Challange and I even checked the RPO codes to make sure. Nice guy. His name is Darren I think and he even has the video showing his car being raced in the Players Challange series. I think he lives on Aquila road just behind McNair. Thanks to both you guys for the advice. Im just a little paranoid.
Old Aug 9, 2002 | 12:23 PM
irocz383's Avatar
Post
I've got Edelbrock headers, gutted cat, 3" headers back into a flowmaster muffler, and dressed up with the 95 Camaro tips!
I have no idea what sereis the muffler is cause I bout the car with it in already and the guy I bought it off of forgot too.
With the new motor I'll just be changing the headers over to the SLP (1 3/4" shorties). I would love to get the Long Tubes but my cars lowered and I really don't feel like listening to hte exhaust bottoming out over speed bumps.
Old Aug 9, 2002 | 12:56 PM
Bristol's Avatar
Post
Cool. I guess my car must sound very similar. I have the same setup but I have a cat that I can just clamp in and take out.
Old Aug 9, 2002 | 01:44 PM
irocz383's Avatar
Post
Not necisarily (sp?)! You've got an extra 50 cubic inches and I'm sure you have more compression and a larger cam than I do.
I haven't heard yours yet but I'm guessing it would probably be a little louder and a faster paced rumble with a lower note. Mines kind of a slow rumble and a mid range note because of the lower compression and lack of a good cam. My exhaust really doesn't get too loud until about 2500 rpm and up!
I really can't wiat to hear what my new motor will sound like!
Old Aug 9, 2002 | 01:49 PM
irocz383's Avatar
Post
Actually... heres my sig. I think I've got just about everyhting covered in there!
1987 Red IROC-Z / 305 TPI / TH700R4
Smoke Show Video (Day1)
Smoke Show Video (Day2)
British Columbia - Team F-Body
Pictures...
Edlebrock headers / Bored out Catilitic converter / Flowmaster muffler / 3" exhaust cut out / MSD 6AL Ignition / Hypertech performance chip / 160 Thermostat / Hypertec pulleys / Posi 3.73's / Shift kit (?) / TC Lock-up switch / Dual K&N's
201 rwhp 285 trq.
best time 14.687 @ 93 mph
In the making...
383 forged L98 / Miniram II intake / AFR 190cc heads / Comp Cam - Custom Grind (230 @ .51 intake 242 @ .54 exhasut) / BBK 58mm TB / SLP 1 3/4" Shorties / Costum tuned chip (4now!)/ 200 shot of NOS to be added later
Expecting ~400rwhp N/A
[This message has been edited by irocz305 (edited August 09, 2002).]
Old Aug 9, 2002 | 06:07 PM
Bristol's Avatar
Post
Hey irocz305 in thet Team F-Body picture, is the black RAM AIR with the cage owned by a guy named Sean?
Old Aug 9, 2002 | 06:11 PM
aklim's Avatar
Post
If it is carb, you can buy a knock unit thingy that will screw into your block and monitor the knocking of the engine and come out as a LED display. If it is modified, like mine, I set it to 6 deg and let the custom chip take over. We customed the chip by taking readings and sending it to www.fasterproms.com and they burnt a chip and we took more readings and burnt it again. Now on WOT, it will knock about 1 - 2 degrees throughout the run which is kinda normal.
Old Aug 10, 2002 | 01:07 AM
Black Robe's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Bristol:
I actually just met another guy with a 1991 white Z28 with a 305 5speed 1LE R7U. Yes the Players Challange and I even checked the RPO codes to make sure. Nice guy. His name is Darren I think and he even has the video showing his car being raced in the Players Challange series. I think he lives on Aquila road just behind McNair.</font>
Can you hook me up with this guy? I have an '89 1LE R7U ex-Players race car (see sig) and would really like to see that video and dicuss our cars.
Larry
'01 Red T/A Firehawk
Convertible, M6, Bilsteins
'89 Red IROC 1LE Prod.
Road Racer, w/Bilsteins
of course!
Old Aug 10, 2002 | 10:53 AM
Bristol's Avatar
Post
Hey Robe. His car is shown on www.1LE.net and its a 1991 Z28 1LE R7U and is under the name DARREN WALSHE. If I see him around in the next littlr bit Ill give him your email. Hey IROCZ305 if yah wanna meet lets do it. If you wanna see some pics they are posted in member rides on IROCZONE
Old Aug 11, 2002 | 12:15 AM
Bristol's Avatar
Post
Did he get in touch with you yet?
Old Aug 12, 2002 | 11:17 AM
irocz383's Avatar
Post
Sorry I didn't reply sooner... kind of bad weekend, cought a cold.
Anyway, yeah thast is Shawn's car... 383 LT1 with 15 lbs of boost out of an ATI DS1 blower.
Whens a good time for ya to meet? Give me a shout on my cell 778-772-9393. Just don't dial 604 cause 778 is the new area code for most new numbers. Its still local so long distance charges don't apply.
Old Aug 12, 2002 | 01:43 PM
Bristol's Avatar
Post
Yah. He works for TD Waterhouse right? I wanted to buy that car a few years ago when he wanted to sell it to get a new Ram Air. Anytimes good for me. I work till 5pm Monday-&gt;Friday andgot stuck working this Saturday. I will call you or you can page me at 604-443-8061 and leave a voice.
