smog pump removal
Old Aug 19, 2002 | 01:30 AM
CtRw's Avatar
Post smog pump removal
Hey guys,
Heres the plan: When it comes time to change my belt, which will be soon, I want to take the smog pump off this beast. Any there any holes that will need to be plugged and if so, what would be the best way to plug them? I've heard the computer doesn't even care once it's gone anyway.
1983 Z-28
305 LU5 V8(Cross-fire Injection)
Radical Cam
Limited Slip Differential w/
3.23 Gears
700R4
T-Tops
Pics-- http://www14.brinkster.com/ctrwsz28/
Old Aug 19, 2002 | 09:09 AM
1989gta's Avatar
Post
you getting an egr plat?
also the converter has a tube coming from it.
Old Aug 19, 2002 | 11:41 AM
aklim's Avatar
Post
I'm pretty sure the computer will know that the EGR is gone. For that, you will have to blank out Code 32 in your EPROM.
You will have to remove the tube going to the cat and plug up that hole. After that, remove all the hoses coming from the pump. Take the valves off the AIR pipes and plug them. Zip tie the wires that go to the AIR valve and you are done.
Old Aug 19, 2002 | 02:25 PM
kandied91z's Avatar
Thumbs up
not sure on the difference between years; but on mine i just left the belt alone and added a delete pulley.......upgraded to headers and zipped off the lines. works perfect. good luck
Old Aug 19, 2002 | 02:58 PM
oliracing's Avatar
Post
Where might one pick up a delete pulley? Say for a car with the serpentine system?
94 Bright Teal Z28 M6, K&N, MSD 6A, TES, Borla, 52mm TB, Lingenfelter ported intake, Hurst, HPP, and BFG Radials,
1986 Iroc
1985 Iroc (Resto)
1990 Iroc (G92 hardtop w/ 5-speed)
Old Aug 19, 2002 | 06:39 PM
CtRw's Avatar
Post
the question: you are gettin an egr plate? Well, I'm assuming I will need that to put over the hole. Delete pully? How's all that work? Leave the pump? Sorry for all the questions! Thanks guys.
1983 Z-28
Radical Cam
3.23 Gears
700R4
T-Tops
Old Aug 19, 2002 | 07:43 PM
90rsMustangkiller's Avatar
Post
go to thirdgen.org they have a tech section on this you dont need a pully delete just a shorter belt
90 rs 305 tbi, Crane cam, comp roller rockers, vortec heads/high rise intake, Ported, TBI w/350 injectors, and all tbi goddies, custom computer chip, tpi computer, 700r4 rebuilt w/shift kit, b&M megashifter, K&N 14x4 open element, 4 3/4" cowl hood, Edelbrock TES headers, flowmasters, 3.23 posi 383 in the works/ B&M th400 trans
Old Aug 19, 2002 | 09:38 PM
amc91z's Avatar
Post
I took my smog pump off and gutted it and put it back on...been going great for about 2 years now
Adam
White 91 Z-28:
Currntly a 305 TPI w/auto car.
Mods:
Comp Cam, ported plenum and runners, AFPR, air foil, 4.11 gears, Hedman Hedders, and a few other goodies...soon to have an LS1 and 6-speed!!!
Old Aug 20, 2002 | 11:37 AM
oliracing's Avatar
Post
Thanks guys!!
Old Aug 21, 2002 | 12:33 AM
CtRw's Avatar
Post
Amc, did gutting it help your performance as much as taking it off would?
Old Aug 21, 2002 | 04:24 PM
amc91z's Avatar
Post
When we gutted it, it had no resistance. You could spin it and it would spin freely.
Adam
White 91 Z-28:
Mods:
Old Aug 21, 2002 | 04:56 PM
Z28Honda-eater's Avatar
Question
Hey -- i want to pull the entire smog system out -- already put a shorter belt on but my question is if i pull the hardware out will it screw up my TPI computer?? isnt there some feedback from it to the brain??
Old Aug 22, 2002 | 11:14 PM
amc91z's Avatar
Post
I've either removed or gutted the smog pumps on all my camaros I've owned and it has never caused a service engine light to come...ie no trouble codes...
White 91 Z-28:
Mods:
Old Aug 23, 2002 | 01:31 AM
aklim's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Z28Honda-eater:
Hey -- i want to pull the entire smog system out -- already put a shorter belt on but my question is if i pull the hardware out will it screw up my TPI computer?? isnt there some feedback from it to the brain??</font>
EGR will cause an error code unless you fix the EPROM. AIR system is controlled by the computer but does not cause problems. If I am not mistaken, the AIR Divert Solenoid diverts air to the AIR tubes on the manifold or headers only when it is cold. Rest of the time it goes to the cat. When it is cold, the ECM is in closed loop and disregards the O2 so it won't notice that no fresh air is going to the manifold which is before the O2 sensor going down from the exhaust manifold or header.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
alphaauto
Jan 23, 2015 07:42 AM
ANDYZ28
Dec 29, 2014 09:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
Timberwolf
Aug 9, 2002 11:24 AM
