2nd gear's crunchy
Old Aug 9, 2002 | 09:09 PM
carcrazyQT's Avatar
Question 2nd gear's crunchy
Has anyone gone through this? What did you do to rectify it? Was it expensive?
1984 Camaro Z28
305 c.i. LG4
Rochester Quadrajet 4-barrel carb
5 spd trans.
Accel Superstock wires
Accel dist. cap & rotor
Bosch platinum plugs
K&N air filter
Dynomax Super Converter
Dynomax Super Turbo muffler
chrome tips
Cooper Cobra 235/60R/15 (fronts)
Cooper Cobra 245/60R/15 (rears)
160F thermostat
...and more to come!
http://members.rogers.com/copperchick010
Old Aug 11, 2002 | 09:14 AM
91RS5speed's Avatar
Unhappy
Sounds like you are going to need a rebuild soon.
http://bitchincamaro.no-ip.com 91 RS Camaro 5-speed black w/t-tops 305 TBI now TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
Old Aug 11, 2002 | 11:16 AM
quick91rs's Avatar
Post
Sounds like the 2nd gear synchronizer is bad. I'm guessing that you probably power shift the car and that is hard on the sychro's. I've actually had one break in half. It's considered normal wear for a car that is drag raced. Replace it or have it replaced. Might as well replace the ones in 3rd and 4th while your in there. The synchro's themselves aren't that expensive. Don't worry about 1st or 5th. 1st gear is never shifted into at speed and 5th is usually not used in a race, so they don't get that much abuse.
91 Camaro RS
Too many mods to list here
81 Ford F100 300 6 cyl (daily driver)
Pacific full suspension MTN bike
Pacific front suspension MTN bike
(spare tires for the Ford LOL)
http://www.quick91rs.cz28.com
Old Aug 11, 2002 | 08:20 PM
carcrazyQT's Avatar
Cool
Thanks to you both for replying and confirming my suspicions. I have learned most of what I know from reading about cars, working with cars, and having worked (and raced)at Grand Bend Motorplex, but it's always reassuring to hear from people who are better-versed in this than I am. I'll have it checked out. Take care!
Tracey
HarleyZ28
Oct 5, 2015 06:23 AM
PCLZ28
Apr 29, 2015 11:56 PM
Biggiebound
Apr 20, 2015 07:16 AM
Jul 4, 2005 05:00 PM
