I need help!
Old Aug 21, 2002 | 01:28 AM
skeelo's Avatar
Question I need help!
I smell gas when my car is running, i think i am getting to much but the shop says im running 35 psi. i smelt alittle bit of gas in the oil when i changed the oil last. how would i go about testing the fuel injectors to see if one of them is sticking?
Old Aug 21, 2002 | 09:57 AM
aklim's Avatar
Thumbs down
For what car? A TPI L98 runs at around 45 - 50 psi. Oil in gas is bad news. I would send it for an oil analysis because that is cheaper than a leakdown test. Oil in gas means a new short block because the gas has seeped past the rings into the oil pan.
