92 RS-throw in an LT1-good or bad idea?
Old Aug 9, 2002 | 05:49 AM
camario's Avatar
Question 92 RS-throw in an LT1-good or bad idea?
my 305 TBI is done! I need a new engine. Should i get an LT1? is it hard to put in? has anybody done it? OR should i just throw in an IROC 350 ???? If anybody has engines for sale email me muj39@hotmail.com
Old Aug 9, 2002 | 06:52 AM
Jim85IROC's Avatar
Post
Both will be similarly difficult. The LT1 will be a little harder because you've got to play games with the accessory pullies to make things fit, and you'll either need to get a 4L60E, or get a vacuum operated lockup controller for your 700R4.
The IROC Homepage
View the Restoration of an 85 IROC
Weekend projects aren't.
[This message has been edited by Jim85IROC (edited August 09, 2002).]
Old Aug 9, 2002 | 08:25 AM
Perry93TransAm's Avatar
Post
If you use a 93 type wiring you can use a 700, Also a place called March sells several different pully arangements and set-ups to do different swaps with an LT1. I dont thin they have a 3rd gen specific set but I beleive they have one that works, also another company sells even better stuff but I cant find their name right off hand, I'll get back to ya.
Perry
Old Aug 9, 2002 | 05:42 PM
Kory 88 Iroc Lt-1's Avatar
Post
Do it. I love mine its not exactly stock but its fast. I have a 4l60e behind it right now. It will break the tires loose at 40 mph. I am working on a t56 conversion which should be even more fun.
Kory
Old Aug 9, 2002 | 06:30 PM
user 647483's Avatar
Post
If you are going to go through all the trouble of swapping engines, you might as well go for the LT1.
If I had the budget and choice, I'd find me a 383 and drop it in. A guy can dream can't he?
Old Aug 10, 2002 | 03:36 PM
irocbob89's Avatar
Post
Go with the lt1, i just started mine for the first time 4 days ago. I cant drive it yet because all the suspension is out but i plan on it being all ready to go the day my suspension comes in. It wasnt that hard, i had a special wirring harnes made for the car and great instructions. The engine has 21k on it with the 4l60E and from the radiator to the drive shaft, including the torque arm it cost me $1400 for the everything including stock wirring. But the after market wirring harness with a custom chip cost $1000.
89' red iroc-z
386 stroker
Mini ram, 58mm tb
30#lbs,255 high flow fuel pump
slp cam, 1.6rr
edelbrock performer heads p+p 2.02 1.60
Hooker super comps, Mufflex 4' exhaust
Ford 9' 4.11 gears, detroit locker, 31 spline
Full suspension
B&M mega shifter,2800 stall
baer rear brakes,line lock
converted to speed density
Ed Wright dyno tuned
89'red Iroc-z 5.7 TPI
t-tops grey interior
free mods, exhaust
Lt-1 convertion in the works
Old Aug 10, 2002 | 04:30 PM
camario's Avatar
Post
hey irocbob where in chicago do you live? i live on the southside near midway. Did you just start doing it or did you just start driving it? It cost you 1400 for everything?
Kory 88 LT1 Can your car boogy? have you raced it on the track?
Thanks for the advice guys.
Jun 6, 2015 08:27 AM
jocamino
May 14, 2015 07:37 AM
eanhl2004
Apr 4, 2015 12:01 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Deadbolt24
Jan 19, 2015 01:29 PM
