Problem
Old Aug 20, 2002 | 10:48 AM
Built350camaro's Avatar
Angry Problem
OK as of here recently i have had some valves tapping, so i pulled my alve covers today and tried adjusting the rockers with the motor running, i got all of them to stop tapping and then one started tapping agin. so i turned it alittle more and i would stop tapping for like 2 sconds then it would start again. also on the one that is tapping the pushrod wasn't spinning like the rest of them were. is this a lifter that has collapsed? or is it a lobe going down on my cam?
Old Aug 20, 2002 | 11:28 AM
aklim's Avatar
Post
If you have a roller cam, there is no adjustment. Make sure all tension is off the particular rocker and then you tighten it till it drags when you try spin the pushrod. Next you turn it a half turn. Beyond this, you will have to remove the manifold and check the lifter. IF YOU HAVE TO CHANGE ONE, CHANGE ALL. Don't cheap out. You are having an older car so if one goes bad, chances are another is on the way.
Old Aug 20, 2002 | 11:54 AM
firechicken_3's Avatar
Post
check the top of the valves, where the rocker meets them, my step dad, had a rebuilt 454 in his 1 ton, and a couple months later, it started to chew up the cheesy cheap valves it came with. it was less than a 1/16th of an inch from dropping a couple of the valves before the mechanics found the problem
84' Firebird, 305ci lg4, 700R4, 288/292 duration .450/.460 lift,Edelbrock Performer intake, Holley 600cfm 4 barrel, K&N filter, Pacesetter Headers, 3'single exhuast, dual out muffler, no cat,Motive 3.73's and Auburn Posi
1/4mile 15.17sec @ 92.5mph
currently in pieces, for manual swap
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
