'82 Z28 questions
Old Aug 23, 2002 | 05:55 PM
ARFFormula's Avatar
Post '82 Z28 questions
I'm probably going to buy an '82 Z28 with the 305 and 4sp manual tranny. Does anyone have any info about these cars??? I won't be changing out the engine for a 350 anytime soon, so what are my options as far as heads(will any of the newer style L98 or ZZ4 heads match up), intake(what type to get), cam(is it a hydrolic cam, will a ZZ4 or LT1 cam fit?), headers...ect. It looks like it will need all the gaskets replaced, so while I'm at it, I want to go ahead and change out all of those things. I know this is a general question, but I would like some info about this car, I wanna pick it up before my funds dry up. Thanks...later
94 Formula A4 - Ported stock heads, LT4 Hotcam,forged pistons, comp cams roller rockers, Comp Cams race-tech pr, borla, Moroso CAI, Edlebrock headers w/Y pipe, LT-4 KM, vigilante 2800, Nittos and a large shot of Nitrous(yet to come, and alot of smaller stuff
Old Aug 23, 2002 | 06:05 PM
ARFFormula's Avatar
Post
Forgot to add, I'm getting this car for a really cheap price(around $100). It runs, but a freaze plug blew out, the radiator has a bad leak, and the engine just looks like it needs to be rebuilt. The cat was taken off and some sort of off-road pipe was welded on. The body is in great shape, ready for paint, the interior needs some work, but not too bad. Is it worth even getting??? I know it's hard to give advise without seeing it, but any advise i greatly appreciated...thanks
Old Aug 23, 2002 | 06:10 PM
carcrazyQT's Avatar
Talking
Um, yeah...if you don't buy it, I will.
I have an '84 Z. The rad only set me back $272 Canadian installed taxes included, and that was heavy duty rad. If the car runs, the rest you can do over time. Sound like an awsome deal. Oh, and my Dynomax Super Conveter was (just a sec while I grab the receipt..) $175 Canadian. You've got a great project car there by the sounds of it. I'd say go for it!
1984 Camaro Z28
305 c.i. LG4
Rochester Quadrajet 4-barrel carb
5 spd trans.
Accel Superstock wires
Accel dist. cap & rotor
Bosch platinum plugs
K&N air filter
Dynomax Super Converter
Dynomax Super Turbo muffler
chrome tips
Cooper Cobra 235/60R/15 (fronts)
Cooper Cobra 245/60R/15 (rears)
160F thermostat
...and more to come!
http://members.rogers.com/copperchick010
Old Aug 24, 2002 | 01:24 PM
CoOrAzY82z's Avatar
Post
Whats up man I have an 82 z28 as well mine came with a carb 305 though at late modle throttal body heads is it the original 305 with cross fire injection ??? most heads adn cam shoudl work as far as i know jus make sure u know the specs about your heads first before you choose a cam like your valve springs compression and that stuff you can go to mortech.com to look yours up jus take off teh valve cover and try to find the casting numbers they should be about 6 or 7 digits long about the headers all third adn fourth gen f-bodies have to have special ones if this is that budget id find em off of ebay hope this helps later dude
Eating rice builds
muscle.
Old Aug 25, 2002 | 02:13 AM
ARFFormula's Avatar
Post
No, it has a carb. I didn't look very close, but I'm sure its a Q-Jet. Just wondering if the new style heads will still fit, using a carb set-up. I'm deffinatly using the budget approach, so I'm gonna check e-bay for heads and intake deals. I already got a cam, an Lt1 and ZZ4, but I would like to know if it would work. I'll get new lifters, springs, and roller rockers and maybe new pushrods and of course headers. What I'd like to do is use fastburn or L98 heads, upgrade the intake, ZZ4 or LT1 cam, roller rockers, headers..ect. Just need to know if it would work. This is a 305, will the 350(L98 ect heads) work??? and on a carb set up???
Old Aug 25, 2002 | 01:09 PM
91RS5speed's Avatar
Post
Your proboly going to have to redrill the holes so your intake will bolt on if you get heads ment for a 86 later sbc.
http://bitchincamaro.no-ip.com 91 RS Camaro 5-speed black w/t-tops 305 TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
Old Aug 26, 2002 | 01:36 AM
smallwood's Avatar
Post
Later model cylinder heads will bolt to the block, but require a different intake due to the bolt pattern. Probably best to go with a crate motor. $100? I'll take five.
Little red light on the highway; big green light on the speedway, hey, hey, hey!
Noenav
Mar 1, 2019 07:38 AM
cmdeshon
Jan 4, 2015 11:15 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Brent94Z
Mar 21, 2002 04:44 PM
