Newbie - Tire size on stock '88 rims
Stock size is 215/65R15.
Would there be any problem throwing 225/60R15 tires on the stock rims for street use? The speedometer will be off by 1.4% but not a biggie.
Would I run into any seal problems?
You should be just fine with that size. The rim shouldn't be too picky about what sixe tire is on it unless you go overboard. You should be able to fit somehtin like a 275/50/15 Nitto on there actually like my friend
Goodluck!
Denny Villemure
1989 Camaro IROC-Z Convertible, 305 TPI, 2.73 Gear, Flowmaster 2 chamber. 15.60 on motor, 14.20 on a 75 shot from NX. Woo hoo!
www.denny.cz28.com
Goodluck!------------------
Denny Villemure
www.denny.cz28.com
The previous owner had put 235/60/15s on the stock 15x7 rims. No problem there. You can definetly run what you want. The 235 made it impossible to scratch the rim on the curb
. Now I have 16x8 polished TT II's with 245/50/16 z rated dunlops (oh so nice)
I bet my speedo is pretty screwed up.
. Now I have 16x8 polished TT II's with 245/50/16 z rated dunlops (oh so nice)I bet my speedo is pretty screwed up.
Thanks folks.
I'm going to go ahead and put 225's on it.
1988 Canadian Iroc 305 TBI
Mods:
Molten rust everywhere
Leaking T-tops
Broken seat tracks
Slow leak on rear tire
Lucky it starts
Mods:
Leaking T-tops
Broken seat tracks
Lucky it starts
I'd go right to the 235s. That'll help maintain a more accurate aspect ratio, plus they'll actually be wide enough to tell a difference from the 215s. 215 vs 225 isn't even worth the effort.
The IROC Homepage
View the Restoration of an 85 IROC
Weekend projects aren't.
The IROC Homepage
Is there any chance I would have clearance problems cranking the front wheels with the 235's or is there lots of room in there?
Mods:
Leaking T-tops
Broken seat tracks
Lucky it starts
Mods:
Leaking T-tops
Broken seat tracks
Lucky it starts
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
