Lost in the terror
Old Aug 13, 2002 | 10:08 PM
MrIROC28's Avatar
Post Lost in the terror
well how can i start this off. I am in need of help from anyone. This is the problem(s) for a while(about 3-4 weeks) my battery hasn't been charging,only going upto the black line just above 8. Before this happened my battery all of a sudden was charging at like 16-17 for like 2 days. Now my car doesn't want to try over. I am wondering if its the altenator, battery, or my electronical system???? Anyone with help on this I would very much appreicate it
Marty
Forgot to mention that I have been recieving a code 32 for about 2 weeks. and today i thought i had fixed it and at the same time the battery indicator was at about11 while running ( this before it crapped out).
[This message has been edited by MrIROC28 (edited August 13, 2002).]
Old Aug 13, 2002 | 10:19 PM
stanghunter211's Avatar
Post
Well, without knowing the specs of your car this is gonna be a little tuff. But incase you didn't know, heres what I have on code 32.
Fuel injected Models (V8 only)
EGR System
restricted Vacuum hose to EGR solenoid or valve;poor electrical connection, open or short in circuit;defective EGR soleniod;defective EGR valve; defective ECM
Carbureted Models
Differential Pressure Sensor
defective DPS; poor electrical connection; open or shirt in circuit; defective ECM
That is what I have on code 32. I know from experience that with my carbed 86, the electric choke got stuck because the regulator in my alternator went bad. My volts were spiking at wot and droping to almost nothing at idle, while the car idled @ 2000 in park. Made the neighbors a little mad till I could fix the problem But I swaped the alternator and no more problem. I doubt this is the same prob for you, just my input. the way our cars are setup, power goes through so many different things, its hard to keep track. It could be any number of things for you. Good luck
Will
'86 Z-28 305 c.i. LG4 165 hp E.T. 16.7 @ 82 mph on radials
Rochester QuadraJet 4bbl,
Flowmaster 80 series, Chrome Tips,
Dual Snorkel Air Cleaner,
K&N Filter,
Michellin P215/65/R15 X-Radial Plus,
Pioneer 4"x6" dash,
Pioneer 6"x9" rear,
Alpine 8" Type S in bandpass box,
MTX Thunder 4202 Amp,
Sony 4000X- x-Plode Deck 50w x4
Soon to be sporting a 350 HO somg legal conversion kit. 308 hp Along with Edelbrock Headers, Edelbrock Performer EGR Intake, and 3" Flowmaster Exhaust with DMH Electric Cutout!!!
Old Aug 13, 2002 | 10:29 PM
BadIroc's Avatar
Post
Sounds to me like its your altenator. The car uses the battery to start then runs off the altenator while running. We'll it sounds like your altenator is cooked and you've been running off your battery for the past couple days...it also could be a problem in your electrical but I'am willing to bet its your altenator, I've gone through 3 and ive had my car for over 4 years...
1988 Camaro IROCZ "MIDNIGHT CRUIZERS"
305 ci Tuned Port 700R4
3"Exhaust/Flowmaster 80 series muffler/Dynomax high flow cat/CutOut
hypertech chip/k&n filers, cut MAF screen gutted air box
"Theres no replacement for displacement"
My Iroc web page....
www.geocities.com/bobfitz82/index.html
Old Aug 14, 2002 | 01:56 AM
RedIrocZ-28's Avatar
Post
BTW, once one dies, the other usually dies. If its your alternator, I'd look into a new battery also. They are kind of a parasitic force upon eachother.
Old Aug 14, 2002 | 12:21 PM
MrIROC28's Avatar
Post
First thanks for your help guys, My car is a 86 IROC-Z 305 TPI. I hope to the heavens i don't need a new battery because i just got a yellow cap optima deep cell batery. Second, when I get my altenator, what one should i get?? should i go to chevy and get one or get and aftermarket one??
Marty
blac94Z
Nov 4, 2015 01:59 PM
WobblySausage
Oct 7, 2015 02:44 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
HAWG
Sep 25, 2015 11:41 AM
