Do I have too many miles for ...
Old Aug 12, 2002 | 05:13 AM
lil305gta's Avatar
Post Do I have too many miles for ...
A cam swap, or should I go with 1.6rr if so what gains to expect and any cam recommendations? 112824 miles on a 305 tpi
1990 Trans Am GTA 305 TPI-SLP Tranny Rebuild Kit w/ Mechanical Diode,Vette Servo, Transgo Shift Kit, Stock Vette Converter. Flowmaster Exhaust, Edlebrock Headers, 3 nch Dynomax Hi-flo Converter, K&N Cone Filter, TB Airfoil. Taylor Spiro 8mm Wires and Bosch Platinums. Pioneer DEH 4300, Audio control 24XS, PPI 500IQX and 200IQX Sedona Amps, 15 inch Kicker XPL Subs, and Kicker 4x6/6x9.
Old Aug 12, 2002 | 06:39 AM
CNCREG's Avatar
Post
I'm in the same boat as you. With that many miles you start doing cam swaps to a bigger cam and rockers your are asking for trouble. It will probably run fine for a bit but you are asking a motor that has a ton of miles to start performing with worn out parts and pieces. So IMO your short term gain is going to cost you a motor rebuild sooner than it porbably would have.
Former F-Bod's:
96 Z28 A4, Airfoil, !TB, !MAF, K&N Filter
89 RS 305/auto
86 Z28 305/Auto
86 LT 305/Auto
86 Firebird 305/auto
81 Z28 350/auto
Currently F-Body-less
2000 S-10 '4 banger with a K&N filter'
I'm Baaaack 92RS 305/auto
Old Aug 12, 2002 | 07:58 AM
Jim85IROC's Avatar
Post
I dunno. It's not like a cam is going to add 100hp and a ton of extra cylinder pressure. It would probably be wise to replace the valve springs at the same time though.
The IROC Homepage
View the Restoration of an 85 IROC
Weekend projects aren't.
Magenta_Hearts
Mar 25, 2015 10:24 AM
Redbird
Sep 14, 2002 09:18 AM
Redbird
Aug 2, 2002 06:50 PM
Redbird
Jul 29, 2002 06:23 PM
Redbird
Jul 20, 2002 06:08 AM
