Rocker Arm Questions
Old Aug 4, 2002 | 01:19 PM
Smooothie119's Avatar
Question Rocker Arm Questions
I was just curious as to whether or not installing different ratio rocker arms would be okay for a 305 TPI engine and if it will actually provide an HP increase or not. A buddy of mine mentioned installing 1.6 rocker arms to open the valves a little more to increase power. Is this possible and/or worth it??
Old Aug 4, 2002 | 03:58 PM
GMTech's Avatar
Post
Is it possible? OF COURSE! Thats the whole point.
Take a camshaft w/ .480I, .510E lift w/ stock 1.5 ratio rockers.
Now replace the 1.5s with 1.6s and now you are running .512I, .544E at the valves.
Webmaster:SETHIRDGEN
GM Tech
ASE Master Auto Technician + L1
1987 Trans Am: 357ci
Ported TFS heads, ZZ4 cam, headers & exhuast and other go fast goodies
13.53 @ 103.77
Old Aug 4, 2002 | 04:12 PM
AutoRoc's Avatar
Cool
Yes it's possible!
I used Crane Gold Race Roller Rocker arms n the 1.6 ratio. Make sure you buy the "Self aligning" units made for 3/8" studs because that is what your TPI engine needs. They should run close to $300 out of a Jeg's catalg if I remember correctly. Goodluck!
Denny Villemure
1989 Camaro IROC-Z Convertible, 305 TPI, 2.73 Gear, Flowmaster 2 chamber. 15.60 on motor, 14.20 on a 75 shot from NX. Woo hoo!
www.denny.cz28.com
Old Aug 4, 2002 | 06:45 PM
CanIroc's Avatar
Post
Denny, was there a noticable difference when you went to the 1.6's? Track times would do fine. I've been thinking about getting a set myself.
Bob
'88 IROC stock 350 TPI, auto, stock 3.27 gears, headers, Flowmaster exhaust, all the free stuff---best et 13.88 @101.18 mph
Old Aug 5, 2002 | 10:19 AM
Question
What exactly will going to 1.6 roller rocker arms do for my car and what kind of performance gains should I expect? Is this safe just to change those? Sorry guys, I'm kinda new with engine components
Old Aug 5, 2002 | 11:02 AM
Stephen 87 IROC's Avatar
Post
When using extended ratio rocker arms you must still be aware of the rest of the valvetrain. Extended ratio rockers are just a poor mans cam swap. They will increase lift and very slightly increase duration. Depending on what cam is in the engine the extra lift gained must be observed. Valve springs must be changed if the extra lift excedes the original springs lift limits. The bottom of the valve keeper must not hit the top of the valve stem also.
Going from a stamped steel rocker to any kind of roller rocker will see a performance improvement. Going from a 1.5 roller rocker to 1.6 roller rockers you should only see about a 5hp increase.
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.589
Best MPH on a time slip: 116
Best corrected ET: 11.079
Altitude corrected rear wheel HP: 468
Best 60 foot: 1.617
Member of the Calgary Drag Racing Association
Old Aug 5, 2002 | 12:33 PM
Perry93TransAm's Avatar
Post
Depending on what year your TPI car is determines wether you need self aligns or not, I have done the swap on 86 and 87 TPI cars and they were fine with non-self aligns, my freinds 91 T/A neede the self aligns. Your springs and such will be fine with the stock cam and 1.6s unless they are already tired. The stock lift is just under 400 on the intake and a little over 400 on the exhaust on the early TPI cars. I gained a solid 2 tenths with my 86 and my 87 with onle roller tip rockers of 1.6 persuation.
Perry
Old Aug 5, 2002 | 02:38 PM
Lightbulb
I should of posted this in my original post. My car is an '87 IROC-Z with the LB9 TPI motor
Old Aug 14, 2002 | 01:28 PM
88Irocker's Avatar
Post
I've heard (from TPIS book - test was on stock '85 vette motor) that 1.6 intake and 1.5 exhst is best...1.6 on exhaust didn't help power and hurt idle quality. Few companies sell a 1.5/1.6 mixed set and they're ususally $250+. has anyone done 8 1.5's and 8 1.6's?? Also, on my '88 305, would 1.6 roller rockers clear the valve covers? How about 1.6 roller tip rockers? I'm thinking of doing this mod and I see that Summit sells a set of 1.6 roller tip steel rockers for $99. Has anyone used the Summit brand? '88 needs the self-aligning rockers, right? Thanks for any help guys.
Go Lil' Camaro Go
OoOoOoOoOohh!
Ramones-Halfway to Sanity @1987
Old Aug 15, 2002 | 08:58 AM
88Irocker's Avatar
Post
OK, I found that the '88 has self-aligning rockers. Anyone else have any imput?
Old Aug 15, 2002 | 10:48 AM
bcirocz's Avatar
Wink
Rocker arm ratios.....Was somebody reading camaro performers this month
Remember to free up your time around June 22 2003 and bring your Camaros to the Peach City Beach Cruise.(Plenty of classic and muscle will be there lets bring the Camaro contingent). For more information see www.peachcitybeachcruise.com .
1989 Iroc Z28 305 TBI
100% Stock (For Now)
1775.Z28
Jan 11, 2015 10:51 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
thenewkid
Nov 27, 2014 09:41 AM
newby
Jul 25, 2002 03:22 PM
