don't want them oval rims
Old Aug 22, 2002 | 08:46 AM
p.parker's Avatar
Post don't want them oval rims
hey i was planning on going to the junk yard around where i live so i could pick up some different rims for my 82' maro just until i can afford some new ones the only thing is i want to make sure they're perfectly round is there anyway i can do that or is it just a roll of the dice??
Old Aug 23, 2002 | 03:14 AM
RedIrocZ-28's Avatar
Post
Well, I would assume that its just gonna be a roll of the dice. Normally its pretty hard to bend a rim. You have to hit a curb pretty hard or fall into the grand canyon of pot holes. You'd probably be able to visibly inspect them. If they are badly scuffed, they are probably no good... Just use your best judgement.
Old Aug 23, 2002 | 04:14 AM
Blownyellow's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by RedIrocZ-28:
Well, I would assume that its just gonna be a roll of the dice. Normally its pretty hard to bend a rim. You have to hit a curb pretty hard or fall into the grand canyon of pot holes. You'd probably be able to visibly inspect them. If they are badly scuffed, they are probably no good... Just use your best judgement.</font>
I would have to agree. Rims don't just wear out and go out of round, you pretty much have to hit something to take them out of round. If you have any doubts about the rim, take it to a tire shop and have it thrown on a tire balancer. If it has bent the barrel of the rim ( which is damage that is not visible or covered up by repairs) it will show up once spinned at a higher RPM. Any reputable used parts place should take back the rim, with in an acceptable time frame without question.
mschmidt33
Mar 15, 2015 07:20 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Kato
Jan 26, 2015 09:21 PM
NewsBot
Dec 3, 2014 12:30 PM
siguy
Nov 27, 2014 10:07 AM
