removal of dampener
Old Aug 11, 2002 | 04:49 PM
holmes677's Avatar
Post removal of dampener
well, the topic says it all. what do i have to do to remove the dampener on my 305?
Old Aug 11, 2002 | 07:54 PM
mod313's Avatar
Post
You need to rent or borrow a puller for it. Also, use the correct installation tool which also be rented or borrowed. Of course if you plan on doing a lot of cam swaps, motor rebuilds, etc. you should consider buying them.
Old Aug 12, 2002 | 05:41 AM
Lars's Avatar
Post
I just did that myself yesterday.. Get the correct puller.. I left the Crank bolt in the crank, without the washer, and then put a small peice of wood in between that and the thread on the puller. It was on pretty right, but surely it was coming off. On installation, get the proper tool as Mod313 said. DO NOT try and hammer it on!!!
Old Aug 12, 2002 | 10:02 AM
1989gta's Avatar
Post
you can tap on the balancer with a hammer while using the puller to jostle the balencer loose the vibrations from lightly tapping help to keep the balancer sliding off.
*** i agree don't pound on or off you will damage something ***
Old Aug 12, 2002 | 11:34 AM
86 redbird's Avatar
Post
I saw just the other day that you can borrow the puller and some other tools from autozone. It takes a deposit(so they know your not going to rip them off) but they give it back when you bring back the tool.
Old Aug 13, 2002 | 02:28 PM
slimdawson's Avatar
Post
Not being funny, but is called a damper. Just thought you would like to know.
Anyway, you can try this. Take the bolt out of the end of it and start the car up. As soon as the car starts and runs, cut it off. Sometimes the balancer will loosen. Good if you don't have the puller.
And yes, Autozone has the loan a tool deal. Just pay for the tool up front, and they refund your money when you take it back. The tools are low quality but the pullers have worked for me. Don't try to use their tubing flare kits, they suck.
Pix of my rides!
Finally have some pictures of Y2k Vette wheels, motor, etc.
*1991 Camaro RS !LO3
8.65@84.3mph NA
*1988 Mustang 5.0 7.92@87 NA- For Sale
*1988 Mustang GT 'vert
9.56@73-bone stock
*1986 Kawasaki Ninja 1000R 7.30@100mph
*1987 Honda CRX Si 16.5@85mph-stock
100% American!
greenzee28
Sep 25, 2015 04:29 PM
Jake Bialke
Sep 24, 2015 11:31 AM
wbspoon
Sep 19, 2015 08:12 AM
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
