What did the TPI cars get that TBI didnt?
I noticed that the TPIs make much more power than the TBI. But it cant all be because of the induction. Where did that other 30hp or so come from ? heads and cam?
James D Montigny
1992 Pontiac Firebird 5.0
Bone Stock Officer, I Swear !
The members of this board are enthusiasts, not experts.
Please consider everything that you read an opinion.
James D Montigny
Yes, better heads, better cam, better exhaust, and 8 injectors at the ports are better than two injectors on top.
1991 Camaro Z28
350 L98 w/ T56 (originally 305 LB9 w/ T5)
318 RWHP, 419 RWTQ
12.803 @ 108.50 MPH (1.932 60')
Member: SoCal F-Bodies
ThirdGen 4-Life!
1991 Camaro Z28
318 RWHP, 419 RWTQ
ThirdGen 4-Life!
So if I swapped out for better heads (Vortec or otherwise), got a more agressive cam, used the TBI setup and installed a 3" catback I should easily make at least what the TPI dad? That's where I was heading with that
I'm not saying one is better than the other, but if I can get more power out of TPI setup, without causing any disadvantages why not ? Especially if I was going to do heads/cam/exhaust anyhow .. it's just a matter of gathering TPI parts.
James D Montigny
<font face="Verdana, Arial" size="2">Originally posted by Kevin91Z:
</font>
</font>
James D Montigny
The only differance is the heads and I think the exhost manafolds. Some of the cars came with an option for the l98 cam in the 305's but not many. That was only in the later tpi cars though.
http://bitchincamaro.no-ip.com 91 RS Camaro 5-speed black w/t-tops 305 TBI now TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
<font face="Verdana, Arial" size="2">Originally posted by 91RS5speed:
</font>
</font>
the L98 also have better flowing heads.
L98 exhaust manifolds are higher flowing than the LO3 and many L98 cars feature a dual cat set up that is supposed to be worth 10-15 hp.
L98's also had the advantage of an intake system taht gm actually put soem effort into developing, stock tbi intakes are basically slightly improved LG4/LG3 intakes.
if you switch to vortec heads and a bit better cam you will be running really good. you will prolly wanna look into a big block(454 tbi from a pick up/ van / winnabega) and you will definately want to get a custom chip burned.
later
tim
NJ SPEEDER
91 Camaro RS
305TBI/700R4
12's Coming Soon
2nd Annual East Coast F-Body Nationals
July 20,2002
www.geocities.com/njspeeder
My MAFB.ORG Home Page
http://www.mycar.net/mafb/registry/detail.cfm?id=299
You can fit a BBC cam into a SBC ? I didn't think that was even possible
James D Montigny
James D Montigny
