how do i remove fuel pump
Old Aug 21, 2002 | 10:34 PM
citizendan1st's Avatar
Question how do i remove fuel pump
hello again...
i have a quick question?i have an 88 iroc z..305 tpi..various mods still runs like crap...but how do i change the fuel pump ?
thnaks again for your help...byes for now..
Old Aug 22, 2002 | 07:21 AM
Jim85IROC's Avatar
Post
You need to drop the gas tank, which means dropping the exhaust and rear axle. Once the gas tank is out of the car, you tap the ring around 1/4 turn and it'll come right up.
The IROC Homepage
View the Restoration of an 85 IROC
Weekend projects aren't.
Old Aug 22, 2002 | 03:44 PM
MRZ28HO's Avatar
Post
Yeah, if you don't know how to work on cars, go ahead and cut the floor. It took me only one hour (by myself) to remove the axle and exhaust, it not that hard. Do as Jim says. Changing manifolds for headers is harder.
George P. Lara
1984 Z28
2001 SS #0391
Mod Videos Page
SCCA, SC3G, GS3, SCFB, SSOA #M01-0391
[This message has been edited by MRZ28HO (edited August 22, 2002).]
Old Aug 23, 2002 | 07:31 AM
bestracing's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by MRZ28HO:
</font>
Being from Cali I can see why it took you only an hour to drop the tank....No Salt Corrosion. The first time I changed one out it took me over three hours to remove the tank because of trying to get all the bolts broke free for all of the rust build up. The next time on the same car it only took an hour but it is still a pain especially if it goes out when the tank is mostly full.
Wayne Best
Best Racing
67 rs Camaro
  • 355 cu in Chevy
  • 12.5:1 compression
  • 10.90s @ 120 mph
87 Formula 350 w/388cu.in. motor
www.geocities.com/best_racing
Old Aug 24, 2002 | 04:42 PM
PonyEtrZ28's Avatar
Post
ok, you do have to drop the exhaust.. but you dont have to drop the rear end. you do have to lower it, but dont drop it out, at least i didnt have to. the job acually wasnt hard. it was just removing everything that was a pain. and the filler neck.lol, when you go to put it back in, make sure you get a little pissed at it so you can jam it back in. but dont break it!. it took me and my buddie about 1hour to do it after i had everything moved and out of the way. good luck man,.
1987 IROC-Z
355ci, Dart 2.02x1.60, compete forged bottom end, SLP siamesed runners, fully ported Edelbrock manifold and plenum, 58mm TB, Accel 26lb Injectors, Edelbrock headers & y-pipe, Flowmaster 3" cat-back, Rebuilt 700r4, B&M Megashifter, Holley 255lph fuel pump, triple guage pod, !A/C & Heat, !Smog pump, bypassed TB, MJS Ram air, custom PROM, Lakewood control lower control arms, Lakewood adjustable pan hard, Sub-Frames, Hotchkis Strut tower brace, Adjustable Torque Arm, 150hp NOS
IROC Pix
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Perry93TransAm
Aug 20, 2002 11:23 PM
