Dumb question?
Old Aug 20, 2002 | 06:20 PM
babyIroc87's Avatar
Post Dumb question?
Right now my car is currently sitting at a mechanic shop about a mile and half away nothing big. The radiator is shot there's a big leak in it. If I need to get my car home would I be able to fill my radiator with water and drive it the mile without doing any damage to the engine or anything else?
Old Aug 20, 2002 | 11:56 PM
STAYBG's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by babyIroc87:
Right now my car is currently sitting at a mechanic shop about a mile and half away nothing big. The radiator is shot there's a big leak in it. If I need to get my car home would I be able to fill my radiator with water and drive it the mile without doing any damage to the engine or anything else?</font>
YOU CAN MAKE IT HOME BUT YOU HAVE TO DO IT QIUCKLY AND TAKE SOME EXTRA WATER WITH YOU JUST IN CASE.
1987 IROC-Z28
355 TPI
58MM HOLLEY TB
HOME PORTED PLENUM
LT1 INJECTORS
HEDMAN HEADERS
CRANE AFPR
MSD WIRES
JET FAN SWITCH.
3' 2 chamber flowmaster cat-back system.
STILL TO COME,
3:73 POSI DISK REAR
4' COWL HOOD
4TH GEN INTERIOR
ALL AROUND SUSPENSION KIT
Old Aug 21, 2002 | 01:28 AM
newby's Avatar
Post
Yah, I've done it before, but make sure you take along plenty of extra water. When you fill it up again, throw in some Redline Water Wetter, or some Stop Overheating. That stuff seriously works.
1986 Z28
383 ci Stroker, Dart Sportsmen 2 heads, roller rocker arms, Crower Hot Street Beast cam, edelbrock 750cfm carb and performer rpm intake, Corvette Servos, shift kit and 2600 rpm stall convertor, 3.73 gears and Eaton limited slip posi rearend.
Old Aug 21, 2002 | 02:01 PM
RedIrocZ-28's Avatar
Post
My suggestion, pull it out of the mechanics shop. Pull into a neighboring business. Get a radiator, bring all the tools needed, and change it right there. It took me an hour to do it. It was the first time I had ever tried anything with cars any bigger than doing a cd player install.
Old Aug 21, 2002 | 11:19 PM
86 redbird's Avatar
Post
If it is a 305 just run it. They can handle the heat. Just kiddin.... just watch your gauge....it should make it a mile unless it is a gash.
Old Aug 22, 2002 | 05:59 PM
stonedchihuahua's Avatar
Post
I ran mine for a week with a leaky rad. I was waiting for the 3 core to come in at napa. I would just check it before I left watch the gauge and it was fine until the thermostat kicked in. Once that happened it would need to be stopped and filled soon
Old Aug 23, 2002 | 04:29 AM
Blownyellow's Avatar
Post
If it is truly only a mile and a half away, you shouldn't even worry about it. Fill the rad full, Start it up let it idle for thirty seconds, and then baby it back to your house. Even if your rad was completely dry when you enter you drive way ( which would be a major leak) you were only going a mile and a half, and your engine temps should not even be at noraml yet. Of course keep an eye on the temp gauge and shut it down if you have to, but you should be O.K.
Old Aug 23, 2002 | 06:26 AM
rudy's Avatar
Post
Leave the radiator cap loose for this little trip.
91 Formula
Sportsman II's, Edelbrock intake, Arizona S/M runners, blah, blah, blah.
ModdedNerd
Dec 25, 2014 05:51 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
donot_4get
Sep 14, 2002 08:03 AM
