PDA
View Full Version : LS1 Based Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68
  1. SLP Level One Suspension any good?
  2. EGR, AIR, Emissions, Headers
  3. Looking to buy 98 Z
  4. true dual over the axle pics
  5. Help with oil leak please! pics
  6. SLP Subframe Install (need help!)
  7. exhaust
  8. Tires !
  9. Eliminating the converters on an 01 SS?
  10. Which header has better gound clearance KOOKS or FLP??
  11. Catalyst under efficiency code?
  12. LS1 speed custom true dual inside
  13. The thermostat
  14. What are the major problems?
  15. Pacesetter Headers...
  16. what is this tube for?
  17. Air Filter....um, filter?
  18. 02 LS1 low rpm vibration..HELP???
  19. My next mods are
  20. fuel line problems (fittings)
  21. Good Cheap Drag Radials?
  22. help custom gmmg
  23. My car has a suspension clunk!!!!
  24. egr delete
  25. SES Light....
  26. Please Help!!
  27. Thinkin about some electrical stuff...
  28. Throttle Lag
  29. WS6 vs T/A Swaybar, is there a diff?
  30. Heads question.
  31. Knocking sound
  32. Changing plugs-99 LS1
  33. Vortec
  34. The honking!! ahhhhhh!!!
  35. Stock ET
  36. where to get billstein
  37. About to pick up my 99 SS now what to do?
  38. RK Sport air/fuel ratio guage
  39. Noticeable difference between styles of subframe connectors?
  40. no cats and no EGR
  41. Installing new Hotcam
  42. o2 sims
  43. heads and cam dyno #s?
  44. another cam question?
  45. slp heads and cam
  46. 1/4 mile times
  47. Oil consumption
  48. Torque Arms
  49. Beware - Found Design flaw in Struts
  50. What kind of xenon bulbs
  51. Fuel Pressure Gauge help...
  52. What brake rotors and pads do you use?
  53. Stinky Interior Question
  54. What do the stock heads cfm flow at?
  55. For those of you w/ 18" rims and Z rated tires
  56. Here's to all the posers out there!!
  57. Oil changing question?
  58. Part number needed
  59. Hesitates at 2000RPMS
  60. Ticking noise in tranny
  61. can i spank a 03 mach 1
  62. what price to have performance clutch installed
  63. Exhaust test pipes
  64. Will They fit ?
  65. what else is needed with a 12 bolt?
  66. sqeaky spring perches
  67. Best sounding LS1 muffler ?
  68. Highest HP (Emmisions Legal) Cam setup???
  69. New respect for the corvette!
  70. cars running 108-109mph... what were your dyno numbers?
  71. Convertable vs. Coupe vs. T-Tops
  72. Oil change caution light....how to reset this?
  73. Trip Meter
  74. help, blowing fuses
  75. Oil Filter
  76. B4c
  77. Popping noise when stopping
  78. popping noise from steering wheel
  79. new exhaust
  80. Jarods short stick VS. Lous Short Stick
  81. '02 SS, non-LE question
  82. 12" Bullet vs. 18" Bullet?
  83. True Duals vs. Catted Y & Cutout?
  84. What if...
  85. Cam Question
  86. stock 01 ss with loudmouth
  87. Cranking noise
  88. ls1 cam with same stats as cc306?
  89. What are all the bolt-on mods?
  90. Yokohama AVS ES 100 tires
  91. Tapping/clicking noise on cold idle
  92. Cam tuning...what is it?
  93. What do you guys think this 99 SS is worth?
  94. EGR/Headers/Intake
  95. how do these compare
  96. Could use a little help installing A/F gauge...
  97. pacesetter header ordeal pt2
  98. ls1 electrical mess
  99. How do you clean out your air ducts?
  100. Finally!!!!! An SLP underdrive pulley
  101. Head/Cam combo that will get 400+ horses/tq?
  102. Exhaust choices and emissions + other power addons
  103. Hear a "whine" at high/high accell speeds
  104. My BFG P255/16/50's showed up today
  105. Not new to Camaros, but new to this forum..
  106. Electric Water Pump
  107. Header problem...
  108. Refi Money
  109. Cons of Free Ram Air Mod
  110. Serious Help Needed
  111. Stall Converter 3000 Or 3500?
  112. SLP's convertible subframe connectors are now available!
  113. Damn bumpy ride is annoying me, help please
  114. LS1 vs LT1 rear rotors. Any difference?
  115. Riddle me this - Why spend $5 grand on Performance, when I can get a complete engine?
  116. Curious as to why?
  117. Exhaust Notes (sound)
  118. damn lt1'ers
  119. what should my car run with these mods?
  120. should I get MAFT?
  121. LS1 cubic question from a LT1 guy
  122. what muffler should i get?
  123. Ram Air hood?
  124. Sold car buying '00 SS
  125. Help determine best cam 4 me
  126. Got my car tuned at Last
  127. Where to find Bare ported LS1/LS6 heads
  128. 2 questions about valvetrain componets
  129. drl problem
  130. Who here has a cutout? Please come inside...
  131. oil light
  132. what should my times be?
  133. TB bypass from Lt1 will it work on my new LS1
  134. loudmouth vs cut out
  135. Couple Cutout Questions
  136. NGK Spark Plug Question
  137. Factory leather question?
  138. Well, I Bought A Car...
  139. Loudmouth Installed today!
  140. Fuel Rail cover Inlays
  141. best MAFT?
  142. Do Not Buy Product From Fiberglass Fabricators Inc.
  143. maf
  144. Best Camshaft?
  145. Time for a new mod-Help me choose
  146. desktop dyno
  147. Hooker Longtubes
  148. Throttle Body
  149. Electric cutout question
  150. Will LT1 342s fit an LS1
  151. SES Light and engine miss
  152. Entire suspension replacement + $$$ amounts?
  153. ls6 cam in ls1
  154. AC belt
  155. Shifter Question
  156. LS1 question
  157. airbox problem
  158. LS1 help
  159. Steering Shaft removal for header install?
  160. Ls1 benefits
  161. What's my approx. increast in HP/TQ?
  162. biggest ls1
  163. First mod. Need suggestions.
  164. Texas Speed Heads/Cam Project Z Wins Quick Stock and runs 10.78 @ 124 MPH!
  165. Revving with No load? How high is to high?
  166. Y PIPE & Headers
  167. wheel alignment specs for the 00 LS1 camaro
  168. thermostat gauge not working
  169. Performance
  170. 1st suspension mod?
  171. da da daaaaaaaa LS1 carbness
  172. Size of exhaust tips?
  173. Magnesium Rims.. Performance gain?
  174. What summer tire should i buy???
  175. dyno / torque questions
  176. Which gets better traction? WS6 or SS?
  177. exhaust
  178. SES light came on..
  179. BLACKWING = The Best
  180. willl having cutout open affect O2 sensors?
  181. Considering swapping an LS1 or LS6 into an MR2, need ideas and info on the motor.
  182. are my pushrods bent?????
  183. lower control arms
  184. most efficient ram air hood(camaro)
  185. Vortech v-9 g-trim VS patroit heads and cam
  186. Stock SS running a 12.8 ?
  187. Question about the Interior Trunk Parts
  188. msd ignition
  189. Best bolt on sub frame connectors?
  190. Paging Quick_lt1
  191. stock 0-60 on 01 SS?
  192. ZO6 MAF on 99 Trans Am
  193. best CAI kit for 99 WS6
  194. short shifter
  195. Hypertech PP3 question?
  196. i got a question about tires
  197. Brake/Rotor Questions
  198. How do i stop this thumping?
  199. suspension questions!
  200. How long do the GS-C's last you guys?
  201. Dyno sheet within , should I be dissapointed?
  202. Suspension-V6 vs. Z28
  203. LS1 cam sizes
  204. 12.8 Rotors /w stock Calipers?
  205. wierd
  206. trade in kelley blue book value 2002
  207. Calculate Crank Horsepower and Torque?
  208. first time on the dyno. how r these numbers??
  209. Brakes and rotors
  210. Need ideas for front plate(long story)
  211. Oil Light
  212. first mods: exhaust?
  213. Donuts without the power steering loss
  214. stupid question...but!!!!
  215. Best type of shifting?
  216. Ls1 Free Mods ?
  217. Exhaust tips
  218. Hotcam before and after dyno #'s
  219. My tire has a flat spot
  220. turbo charger
  221. Help with headers
  222. warranty on leather seats starting to crack
  223. Will a ZO6 clutch master work in a F-Body?
  224. Stock LS1 to LS6...
  225. Warranty Service
  226. Okay, Im trying to figure something out.........
  227. clicking on slow speeds
  228. Stall installed,now car runs funny,HELP!
  229. Check this install out...
  230. 98-99 slower? vs 00-02
  231. EGr and aiR
  232. new springs, something wrong
  233. anyone know who's car this is?
  234. RE: est gains from a kn fipk and loudmouth
  235. 2000 pacesetters on a 99?
  236. Water temp gauge for 2001 Camaro SS
  237. Engine Noise
  238. clicking noises
  239. Alarm/Keyless remote problem
  240. headers...
  241. stock 99 SS 1/4 mile?
  242. how to shorten?
  243. SLP Long TUBE Headers
  244. t-top rattle fix?
  245. carfax report needed
  246. LS1 port & valve size?
  247. Dynomouth
  248. A4 guys....Idle question?
  249. how much to resurface front rotors?
  250. stupid ?
