Good Cheap Drag Radials?
Old Nov 20, 2003 | 04:11 PM
allnet777's Avatar
I need new tires in the rear. I am looking for some drag radials that are the best bang for the buck. I dont have alot but I odnt want to purchase a bad product, any ideas?
Old Nov 20, 2003 | 04:20 PM
2000zee28's Avatar
Nitto Extreme drag radials for day to day and at the drags.
Old Nov 20, 2003 | 04:30 PM
Mikael's Avatar
tirerack has 315mm BFG's for $149
Old Nov 20, 2003 | 04:31 PM
ULTIMTEORANGESS's Avatar
nittos are ok but dont hook hard.descent but not great.theyre good for everyday driving in dry,warm weather but suck if its wet or cold.they wear good though.
Old Nov 20, 2003 | 04:46 PM
2000zee28's Avatar
I drove 12K on them rain or shine and they were great.
Even drove on them during an ice storm or two and they
performed like a normal tire.
Old Nov 20, 2003 | 04:54 PM
do you lower the pressure?mine feel outright dangerous.i dont think you get the same winter weather as i do.
Old Nov 20, 2003 | 07:06 PM
96SFLZ's Avatar
BFG's and Nitto's are the only two that you should consider, IMO.
I don't think there's too much of a difference in price between them. BFG's will hook a little better than the Nitto's but they'll wear a lot quicker too.
Nitto would my choice because they will last longer and IMO they hook plenty good...good enough to break the 10-bolt (you probably won't but you definitely could).
Old Nov 20, 2003 | 07:42 PM
allnet777's Avatar
How much are the Nittos and the BF's for a pair?
Old Nov 20, 2003 | 08:13 PM
Fred94LT1's Avatar
Cool
Nitto's aren't that bad in the rain. I used them on my 94Z28 & never had a problem. Granted I knew better than to drive aggresively with them when water was on the road, but I don't do that with street tires.
As far as desireable drag radials there are three categories i'd look at. Traction on dry pavement ET Streets! 2nd BFG Drag Radials! 3rd Nitto's.
Wear length Nitto's win! 2nd BFG's 3rd ET Streets.
Street & track combined use considering all weather conditions.
Nitto's! 2nd BFG's never when wet really. 3rd ET Streets never when wet period!
That's my opinion, Fred
Old Nov 20, 2003 | 08:20 PM
chpmnsws6's Avatar
couldn't of said it better myself!
tekker's Avatar
ok wtfz >_< you said you need new rear tires. do you need new rear STREET tires or want some radials? radials = not daily driver and of course they will feel dangerous in any driving conditions but dry.. for good rear street performance tires id go with Yokohama ES 100's or Nitto555's.
now if your looking for radials the Comp BFG's are good but i wouldnt leave out Mickey Thompson ET Drag's either
/tek.
Old Nov 20, 2003 | 08:25 PM
Fred94LT1's Avatar
For what's it's worth I paid $312 for my BFG Drag rad's to the door step from Summit. You can get them cheaper from the "TireRack" but there back ordered with no info on when the next shipment will come in.
Old Nov 21, 2003 | 09:14 AM
Black01_Z's Avatar
BFG G-FORCE TA Drag radial. If you get a BFG make sure you get these. Do not get the Comp TA. I had the G-Force on the rear of my car and I can tell you one thing. Nothing in the world ever hooked like these tires. They were beyond amazing it scared me. In several tests in magazines when run at 12 psi at the track these things can perform like slicks. I wouldnt recommend running 12 psi on the street. At 35 psi on stock or close to stock car you should be just fine.
Old Nov 23, 2003 | 10:25 PM
96LT14u2Nv's Avatar
in my experience Nittos are better on the street and BFG's are better at the track. The BFG's grab better bhut tend to toss more rocks and road debri than the Nittos.the nittos are basically a really grabby street tires.
Old Nov 24, 2003 | 02:20 PM
psychocabbage's Avatar
/tek.
they are all radial tires...
BIAS is the other type of tire that is not as common. Usually found with tires needing tubes.
For street - go with Yokohama AVS ES100's
For track - Either the Nittos Extreme Drag for much daily driving as stated or the BFG Drags for more track time.
