02 LS1 low rpm vibration..HELP???
Old Nov 20, 2003 | 08:48 PM
driftwood's Avatar
Question 02 LS1 low rpm vibration..HELP???
I got this 02 35th anniversary edition convertible with auto that came into work today with a vibration from 700-1100 rpm.It only does it in gear and I can only get it to do it when cool,once warm,it lessens.It is mainly heard in the interior,but you can feel it under the hood on drivers inner fender,like if you hold the AIR hose.
I set the park brake,dropped it in gear and used the TECH 2 to raise rpm til it would vibrate,then went looking.I do notice the drivers side part of the Y pipe seems to vibrate a lot,but applying pressure to it does nothing.
I did not find any loose mounts or x members.It seems like something harmonic,aybe in the convertor or low end of engine.
Has anyone had or heard of anything like this??Please let me know.
Thanx,Joe
Old Nov 20, 2003 | 10:16 PM
Fred94LT1's Avatar
Sounds like the air pump to me.
timmy39120
May 8, 2015 11:41 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
