What brake rotors and pads do you use?
After a little spirited driving my brakes started thumping a little again. Not like they're warped either. Looking through the wheels I can see the RF rotor has a 1" crack in one spot. You can feel it bump up when you run your finger over it too. I figure I should get some better than stock rotors and pads to prevent this from happening again.
What do you use and would you reccomend it?
So far I'm planing on power slot rotors and napa ceramix pads. I don't auto-x, but I do brake hard at times. I try to avoid alot over engine braking with my M6(trying to see if it helps oil cinsumtion). This is my daily driver.
Originally posted by 8850
Not sure what to tell you to get but don't get the Baer Eradispeed Plus rotors. Mine sure warpped. I had them turned and they are fine now.
Originally posted by KungFu
I assume their warped rotor policy sux? I was thinking about getting some for rear replacements.
Thanks for the input so far. Nothing bad about power slot rotors that I can't handle. Since I work at a shop I can warranty any pads from napa whenever I think their too noisy. Rotor warranty isn't so great and can be a pita trying to get them to cover rotors. I've heard nothing but good stuff about autozone rotors, but I don't need to get into all the reasons I'd rather not go there. Brake dust isn't much of an issue because I wash my car(and wheels) at least once usually twice a week(its black).
whitehooptie
Jul 12, 2015 06:10 PM
