egr delete
Old Nov 19, 2003 | 09:32 PM
19ss99's Avatar
Question egr delete
Have a 99 ls1, want to throw the ls6 manifold on, but they are starting emission testing here in PA. I know i can have it removed by using ls1edit, but when they plug me in to check for codes will they be able to tell its missing? Anybody ever change up to a 01-02 pcm to have no worries?
Old Nov 19, 2003 | 10:14 PM
2000zee28's Avatar
I had the same issue. Got rid of everything but the EGR.
I took it off the mount moved it and the harness over by the A/C lines. The PCM is looking for a voltage change ( feedback ) to the PCM. No codes, no problems, No LS1edit.
Old Nov 19, 2003 | 10:19 PM
19ss99's Avatar
really that worked? cool! I was thinking it would have measured something, but guess its only more/less a valve. i never thought about doing that, thanks
Old Nov 19, 2003 | 10:24 PM
2000zee28's Avatar
No problem. By the way if you already SES coded for this, hook the EGR back up and it should clear the SES after 20 key cycles.
It's nice to have buddies with TECH2's also
Old Nov 19, 2003 | 11:34 PM
chpmnsws6's Avatar
so would it throw a code if i had it all wired up but i cut the hoses off so air went inside one end and out the other?
Old Nov 20, 2003 | 07:39 PM
2000zee28's Avatar
I think that would be the best setup. I did forget to mention you should ground the EGR unit, or install it as you suggested. The only down side would be you have cut up a part you may want someday.
Old Nov 20, 2003 | 08:12 PM
chpmnsws6's Avatar
i'm trying to sell the car and the SES light was on because of it. it makes ppl instantly turn away when the ses light is on
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
tnmotown
Aug 10, 2015 11:52 PM
