ls1 electrical mess
Old Nov 14, 2003 | 05:14 PM
Devast8rSS's Avatar
ls1 electrical mess
Was doing the wire location mod on the Ss to hide the 0ga and the ugly *** engine connectors that run down the passenger side of ls1 fbodies, and all went smooth except for having some roommate help .. Bottom line is there are 3 connecotrs that are involved in this relocation , a 5 wire one a 8 wire one and a 9 wire one.
which opens this three part question ?
Problem with 5 wire one is SOLVED !!!
Problem with the 8 wire connector is there are 2 Pink wires (B) and (E) positions. on 8 pin conector now I couldnt trace these back to any set pcm location as i believe they are common because i would get a continuity reading on most pcm pins but from the master pcm pin out list only 2 pink wires or red 63 (trany range signal A) and on blue (19 ign positive voltage )but I need some advise there
And now for the real pain
On the 9 pin connector there ar 6 wires in question
2 green, 2 blue , 2 pink (green J & C) (blue E & H) (pink A and G) that also seem to be every where on the Pcm so trying to corolate conector loaction (letter) back to Pcm pin # so that i can verify done right and have car start again,,,
thanks for any input
Boss002
Jul 9, 2015 03:33 PM
mrwz28
Jul 8, 2015 09:11 PM
camaro02DK
Jul 5, 2015 09:04 AM
Jmlcolorado
Jul 4, 2015 08:31 AM
