LS1 cam sizes
Old Nov 9, 2003 | 01:24 AM
Formulized94's Avatar
LS1 cam sizes
What is the talles lift cam you can install in a ls1 with stock pistons, and valves? or that i known installed in an ls1?
Old Nov 10, 2003 | 12:15 AM
Angry
Do you people just not know anything or just dont read english? Seems this is the only message board that people do no reply. I do not know what it is lack of knowledge, or just do not care. Oh well
Ryan
Old Nov 10, 2003 | 06:20 AM
dist0rtion_69's Avatar
Depends on the duration.. I am running .581 lift with no probs at all.. I think anything over .600 is going to be a tight squeeze.. especially with over 230 degrees of duration.. Many of the bigger cams on the market or soon to be on the market are requiring flycutting of the pistons. However, the limit is somewhere close to as stated above.. If you plan on using a cam this big, please do the clay test..
Cheers,
Old Nov 10, 2003 | 11:23 AM
SSCamaro99_3's Avatar
G5X-2 232/240 .595/.609 112 lsa is about as big as they get before you start flycutting pistons.
Old Nov 10, 2003 | 06:53 PM
Thank you guys, I was planing on the G5x-2 I have not heard much about it. Is it a good all around power cam?
rideordie
Nov 5, 2019 04:52 PM
HectorM52
Jul 30, 2017 11:46 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
ChrisFrez
Nov 23, 2014 10:33 AM
