View Poll Results: How much oil does your ls1 consume per 3k miles?
.25 quart
15.38%
.5 quart
15.38%
.75 quart
7.69%
1 quart
38.46%
more?
23.08%
Voters: 13. You may not vote on this poll
Oil consumption
Old Nov 17, 2003 | 01:11 AM
coletrickle350's Avatar
Question Oil consumption
Hello all this will be my first post in the ls1 section.
I'm an Lt1 man so bear with me.
My sis picked up a 2000 ws6 not to long ago.
Its been 2k miles since i changed the oil last and the low oil light came on and the car was a little over a quart of oil low.
I checked for leaks and there is nothing to be found.
The car only has 30k miles on it.
Does that sound normal for an ls1?
How much oil do your ls1's consume?
Oh and how much oil are ya supposed to put in an ls1 anyways?
Old Nov 17, 2003 | 02:05 AM
99blackSS's Avatar
I don't burn any, theres no "none" option in the poll.
It is pretty normal for the LS1 to burn about a quart in between oil changes. A little over a quart after 2k sounds a bit high. Oil pan holds 5.5 quarts. But usually end up pouring in about 5 quarts. Buy a case of six and you'll have a spare quart for when it burns oil in between changes.
Old Nov 17, 2003 | 07:22 AM
NEWBIE T/A's Avatar
Lightbulb 'Bout a 1/2 qt every 3K .
From what I understand, it has the potential to be worse w/ a manual as the engine spends more time in a high rev, no load condition - as in coasting down from speed, or if the engine is being revved at high rpms , but not under WOT - as in you should shift, already !
Mine's an A4 w/ a stall, so I believe that "helps" the condition.
No biggie, all in all - just gives me another excuse to pop the hood & admire my motor !!
Welcome to the
world of the LS1 !!
Britt
Old Nov 17, 2003 | 02:05 PM
Z28x's Avatar
Using Synthetics the engine consumes a little more
I use Mobil 1 5w-30 and add 1/2 quart every 4,000mi
Old Nov 17, 2003 | 05:26 PM
autoguy's Avatar
hmmm.... i haven't noticed any oil consumption with my ls1... do i have one of the rare ones that don't use any oil LOL i have just under 12K miles on it. i don't notice any pistion slap either.. maybe a lil at startup but goes away almost immediately. maybe i have one of the good ones LOL just thought i'd let you guys know
Old Nov 17, 2003 | 05:32 PM
DanBUCF's Avatar
The problem is more so with manual transmission cars, and it is even more present when the driver downshifts to slow down. It creates some sort of vaccum that will suck oil past the 2nd piston ring. Its a documented problem by GM. They will do an oil consumption test on your car if you bring it into the dealership, and if you "pass" the test (meaning your car eats enough oil), they'll replace your piston rings under warranty. Its about a $1,600 job that GM will eat.....I had mine replaced last spring.
I haven't used a drop of oil since the work was done to my car, and I use synthetic as well. I reccomend getting it done sooner than later while your car is still under warranty if you are using excessive amounts of oil.
Old Nov 17, 2003 | 06:04 PM
demonspeed's Avatar
None with Mobil 1 530
Old Nov 17, 2003 | 07:48 PM
99BlackZ28T56's Avatar
First 3k used no oil. Then I added Mobil 1 and was a quart low at the next change. Noticed oil in the intake so I installed a ls6 PCV valley cover and so far so good, but only 1k mi so far. 58k mi now.
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
