ZO6 MAF on 99 Trans Am
Old Nov 9, 2003 | 08:18 PM
fast_TA_95's Avatar
i have a 99 Trans Am WS6, i have the Slp flow pac kit ( Slp lid, Slp cold air kit, K&N filter, and Slp smooth bellow. I want to get a very good MAF, what is the best one? I work in a Gm parts Department at a dealership, and i can get a brand new (2003) MAf for about 190$ should i get this MAF or look into a Granetelli, or a SLP. And do i need a adapter if i were to buy the ZO6?
please resond! thanks for your help!
Old Nov 9, 2003 | 09:47 PM
Pandamonkey's Avatar
Like you said, Granatelli makes one that should suit your needs.
They're about as good as they get.
Old Nov 9, 2003 | 10:04 PM
pu12en12g's Avatar
I have a brand new Z06 MAF for sale. Let me know if you are interested.
Old Nov 10, 2003 | 10:27 AM
Brent94Z's Avatar
Super Moderator
I'll move this to the LS1 Tech forum...
Old Nov 10, 2003 | 11:51 AM
FacelessZ's Avatar
Granatelli is a plastic piece of s h i t! No way is it worth the $269...if you're going to step up your MAF go with the Z06 conversion and save $100...
Old Nov 10, 2003 | 04:31 PM
slow's Avatar
want a good maf, buy one from a 99 TA
stock is best when it comes to mafs, unless you max yours out. imho.
maf calculates load, load controls lots of things in the computer, timing, fuel, shift points, ect.
Ryan. .
Old Nov 11, 2003 | 02:45 PM
fast_TA_95's Avatar
MAF
Thanks a lot guys, i will probably go with a zo6 maf, but i have read that you need a adapter to make this conversion work is this true?
Old Nov 11, 2003 | 04:02 PM
FacelessZ's Avatar
Go to www.ls1speed.com and look under Induction...about half way down the page you'll see the 85mm Z06 MAF conversion kit for $149.99...I believe it's the MAF from a 2001 Z06...
Old Nov 11, 2003 | 05:54 PM
V6toZ28's Avatar
Ryan. .
You're part way right ... the MAF doesn't do the calculations ... it simply supplies calibrated data to the PCM ...which does the calculations.
Which is why Z06 is of little or no value on an F-body ... the MAF is going to be supplying uncalibarated data to the PCM and the calculations will be inaccurate ... even the so called "calibrated" MAFS still supply inaccurate data ....
The money is better spent on a good tune ...
Old Nov 11, 2003 | 05:59 PM
fast_TA_95's Avatar
MAF
so what your sayin is that i should just leave the stock MAF in my 99 TA, i put a granetelli on my 95 TA and i couldn't feel a thing. I spent 360$ on that. So my question is, is there a benifit to getting a ZO6 MAF or just leaving the stock one in there?
Thanks alot for the help!
Old Nov 11, 2003 | 07:24 PM
Fred94LT1's Avatar
What are your current mods?
I'd spend the money for real HP in the way of a 3" Y-Pipe if it was me.
I've got the Black SLP maf ends on my otherwise stock maf. Until you get heads & or Cam setup your fine IMO, Fred
Old Nov 11, 2003 | 08:23 PM
ULTIMTEORANGESS's Avatar
you could end up losing power.keep your stock MAF.
Old Nov 11, 2003 | 10:17 PM
rick99ws6's Avatar
I have the LS6 cam and heads. Would I benefit from the ZO6 maf ??
Old Nov 12, 2003 | 01:49 AM
zoomjrl's Avatar
Yeah I've seen several sites advertise that 10hp gain from the SLP 85mm MAF. If I WERE to get one it would be a GM Z06 or SLP one cause SLP is as close to stock compatible as it gets. I wish to do a Cam and my goal is 400wrhp, I was told that a new MAF is not needed. The only thing that keeps me guessing is that I read somewhere that the screen actually helps perf by straightening airflow for the sensor, descreening throws the reading off and makes the car run lean. The SLP 85mm MAF still has a screen, and we are always told that more flow = more power. But I think to make it work you would have to have that capacity to flow from front to back, meaning Lid, MAF, Throttle body, and prob even the Z06 Intake.
Old Nov 12, 2003 | 10:48 AM
V6toZ28's Avatar
One more time ... the MAF is a measuring device ... it provides very specific data to the PCM ... change the MAF and the data is inaccurate.
