Oil changing question?
Old Nov 16, 2003 | 07:09 PM
93 LT1's Avatar
Guys, on a 02 SS that has about 700 miles on it, should I change the oil? The oil is orginial. Should I add some the GM break-in additive when I change it? It has been in there since the car is new, but I heard to not change it for like 3K? So what should I do to break the engine in properly? Im going to use regualar oil first.
Old Nov 16, 2003 | 07:21 PM
Slappy3243's Avatar
Straight out of the factory I changed my oil at 500 miles just in case any debris from the brand new engine may of came loose during the break in period. After that, its every 3000 miles with Mobil 1. That is my routine anyway.
Old Nov 16, 2003 | 07:46 PM
psychocabbage's Avatar
I went 0-4225 changed to mobile 1 oil and filter
4225-9100 (4875 miles) changed all fluids in car to amsoil for a test
9100-16520 (7420 miles) changed with amsoil again
16520-24459 (7939 miles)Part amsoil part Mobil 1.
I use my synthetics for the purpose they were built. To extend my oil changes.
Old Nov 16, 2003 | 08:51 PM
93 LT1's Avatar
so you guys are saying I should change it??
Old Nov 16, 2003 | 08:57 PM
Slappy3243's Avatar
I would change it after the first 500 miles. Then do as you please as far as intervals go.
Old Nov 17, 2003 | 09:26 AM
NEWBIE T/A's Avatar
Lightbulb Yup - change the first out fairly quickly.
I did that on my '99 T/A at around 500 miles, and on the wifey's '02 Saturn at 600 miles.
Per my hot rod mechanics suggestion.
I waited 'til around 5K before I experimented w/ syn oils, but I do not think using syn prior to that will really have an effect (negative).
If it did, would they use it as factory fill in the Vette ?
I try to go 5K on name brand Syn oils - 3K on dino.
I have yet to hit that mileage, though, as the oil change light comes on prior to 5K and I change it at that time.
Came close this last go-round w/ the Royal Purple - like 4700 miles, including 1 trip to the drag races & about 7 passes.
My .02.
Britt
Old Nov 17, 2003 | 09:34 AM
Darth Xed's Avatar
The key here isn't the milage... it's the fact that it is the original oil... in a 2002 vehicle...
Yes, you should change it. For $20, it'd be kind of silly not to... error on the side of caution, IMO.
Old Nov 17, 2003 | 10:10 AM
demonspeed's Avatar
I'd agree
Old Nov 17, 2003 | 04:49 PM
93 LT1's Avatar
OK, sounds good...change it.
NOW, my 2nd question, plain and simple should I add the GM break-in additive when I change it??
Old Nov 17, 2003 | 05:08 PM
demonspeed's Avatar
???? I looked in my owners manual and couldn't find anything about a break in additive.
Old Nov 17, 2003 | 06:21 PM
93 LT1's Avatar
Thumbs up
Well Im asking because to break in properly GM puts an additive in all new oil when it leaves the factory and I heard it should be in there for 3K. I know the oil needs to be fresh and since mielage is low the engine might not be broken in. But a lot of you guys said you changed @ 500 and put regular oil in? So im not sure what needs to be done yet in regards to this.
Old Nov 17, 2003 | 08:39 PM
96LT14u2Nv's Avatar
it cant hurt for the price that it cost. if it doesnt really need it, just do it for piece of mind.
Old Nov 18, 2003 | 03:49 AM
AL SS590 M6's Avatar
Moderator
Well I've worked at GM for 34 years and never heard of putting any break-in additive in.
I always change the original oil out at 500 then regular intervals from there on out. My Buick has almost 200,000 miles on it and I still don't have to check it between changes. So I don't think that it hurts them.
Old Nov 18, 2003 | 09:27 PM
93 LT1's Avatar
Thanks guys. I appreciate your replies. I will change it ASAP with regualr oil.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
Sandersen511
Jan 13, 2015 03:49 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
Jul 4, 2005 05:00 PM
