Electric cutout question
Old Nov 12, 2003 | 09:45 AM
Tucdog's Avatar
I am most likely going to go this route. Since I am setting up my ashtray switch panel for my nitrous, what kind of switch do the different electric cutouts use? Are they single momentarys or are they like the NX bottle opener with a center neutral position, forward momentary open, rear momentary closed?
Old Nov 12, 2003 | 04:53 PM
99BlackZ28T56's Avatar
My MPP2 only moves while holding the switch. It comes with a led that lights when it is open or closed, or when not open or closed(ypure choice). I went with the convertible switch option that has a relay right on the switch. Then I bought the factory mounting plate from the dealer(less than $5). I also scraped off the part that says TOP and repainted it. Then I etched EXH in place of the TOP. So when The cutout is open or closed it lights up the EXH. I like it. Just looked at the site and don't see it as an option anymore.
Old Nov 12, 2003 | 08:20 PM
Klypto's Avatar
where to get an ashtray switch plate? i couldnt find them anywhere.. needs 3-4 switched on it... kthx
cory
Old Nov 12, 2003 | 08:38 PM
CableWS6's Avatar
when i got my ta it already had a cut out on it so i was wondering which one of the electric ones fit mine?
Old Nov 13, 2003 | 09:15 AM
Tucdog's Avatar
Klypto,
Jimmy-jams.com will hopefully have these in the next two weeks. They already have them for 93-97s, but are in the process of making the 98-2003 plate. Should only come out to around $30 with switches. Someone makes them and sells on LS1.com but they want over $80 for it.
Old Nov 13, 2003 | 03:53 PM
95 Silver TA's Avatar
They usually come with the rocker switch. The best place to buy a cutout from is DMH. They have the Best warranty, best materials and have the best tolerances.
You can check up my write up (with pics) on it here:
http://camaroz28.cardomain.com/memberpage/342629/5
And on this site you will see and hear the difference between the sound difference on my car, You will need QuickTime to View:
http://home.comcast.net/~mootoo/ANTI-VENOM.html
Thx,
Claude
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 29, 2002 11:01 PM
Rich_z28
Aug 29, 2002 10:44 PM
stanghunter211
Aug 29, 2002 03:04 AM
