What do the stock heads cfm flow at?
Old Nov 16, 2003 | 08:52 PM
1KillerV6's Avatar
I found a nice set of heads for a decent price. These Heads Will Flow Over 200cfm At 0.300" Lift And 290+ At 0.500". The valve sizes are, 2.02 intake and 1.575 exhaust.
What are stock valve size? 2.00/1.55 and does it make much difference?
Old Nov 17, 2003 | 12:57 AM
pookie's Avatar
heads
Im not sure what the stock heads flow #s are but the the valve size is 194/150. You will not really notice much upping the valve size on the head. The real power is noticed with a good old port and polish with bigger valves. I tried 2.00/1.55 and was very disapointed. Nothing like pulling the heads twice! I did a home port and polish and the valves were done at the machine shop.
Old Nov 17, 2003 | 07:16 AM
Mikael's Avatar
Around 250cfm at .500 on the intake..... silly me, i forgot thin exhaust
Old Nov 17, 2003 | 02:00 PM
dnz28's Avatar
http://www.malcams.com/legacy/misc/headflow.htm
Old Nov 17, 2003 | 03:25 PM
V6toZ28's Avatar
Intake.. Exhaust.. Lift
134...... 98........ 200
189...... 130....... 300
222...... 152....... 400
240...... 175....... 500
252...... 182....... 600
I got it from a very unereliable source ... was in a post I saw somwhere on the internet ... copied if for posterity
Old Nov 17, 2003 | 09:49 PM
1KillerV6's Avatar
So i'm guessing the heads I like are good.
Go here and scroll down a little more than half way a look and the heads that says LS1 - LS6 Street/Strip Cylinder Heads are the ones i'm liking. The Patriot Performance CNC Ported Cylinder Heads above don't look too bad either.
Old Nov 17, 2003 | 09:52 PM
1KillerV6's Avatar
Which are better out of those two? How about for value?
Old Nov 18, 2003 | 03:37 AM
AL SS590 M6's Avatar
Moderator
Re: heads
quit quoting LT1 specs. They don't help out here at all.
LS1 5.7 stock heads have 2.00/1.55 valves.
Old Nov 18, 2003 | 09:11 PM
1KillerV6's Avatar
so........is there much difference in the 2 heads I like in my 2nd to last reply
Old Nov 18, 2003 | 09:23 PM
dnz28's Avatar
my bad I thought this was in lt1 tech. i should have looked before I clicked.
Old Nov 18, 2003 | 11:22 PM
V6toZ28's Avatar
Never heard of the one .. the patriots are getting a lot of play on the boards ... and some good numbers are being reported ...
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jun 23, 2016 08:42 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
MadMav
Feb 6, 2015 11:02 PM
Killer94z
Jan 13, 2015 12:06 PM
