making a 7.5" stronger
what can i do to make the stock rear end stronger? i have a ta girdle. would an eaton or auburn and a solid pinion spacer help too. i cant afford a 12 bolt right now
Re: making a 7.5" stronger
Originally Posted by Capn Pete
Pull about 4 of your plug wires off, then the rear end will seem stronger!!!
Tom
Originally Posted by SloTexanTA
He's actually kind of right. The real weakness in the 7.5" 10-bolt is the gears themselves, not necessarily the axles. You could throw in as much money as you wanted to in the rear ends, upgrading axles, different posi-units, etc., but the size of the ring gear will still be a major weak point. Luckily you have an auto, less shock on a hard launch on slicks, so your axle may last longer. You're best bet would be to keep of the hard launches and slicks until you've saved enough for a 12-bolt or a 9".
Tom
Tom
I've been running 420rwhp thru my 7.5 for 10 years...As said before the weak link is the 7.5" ring gear, but I've found that stock axles, a Pro Auburn limited slip, GM gears, a TA style cover (mine's a Summit one from Spohn, which was just added a few weeks ago..) and BFG Drag Radials seem to be the right combo for an A4 car...Decent traction, but just enough tire spin to avoid breakage...If you are serious about hooking hard on ETs or slicks then don't bother with the 7.5. Save for a 9" or 12 bolt. Just my .02...
--Alan
--Alan
I'd say probably the "strongest" 10-bolt setup there is would be getting 4.11's (not 4.10's) where the ring gear is 37 teeth instead of the standard 41 teeth. The pinion has only 9 (compared to 10, 11, or 12 for typical 4.10 / 3.73 / 3.42 applications) but the fewer # of teeth on the ring & pinion makes it that they are actually thicker, and thus, should be stronger
Sorry about my smart-*** comment earlier........I wasn't trying to offend
Z95M6 what did you have to do to put the 8.8 in your car, and was it the one out of the 95's or so that already has the abs? i can get one of those from a friend
importkiller94
Jan 17, 2015 09:03 PM
