Thinking of a lower gear ratio?
Old Sep 2, 2004 | 02:14 PM
99_Z_155's Avatar
im thinking of lower gears, like 4.10 maybe, but what will that do for my nearly stock car? will it lower quarter times? help alot on launch? will my car handle a change like that for daily driving? And also, if any of you guys have the M6 with these gears, at 65 in 6th, what rpm's are you running?
Old Sep 2, 2004 | 06:11 PM
unvc92camarors's Avatar
Re: Thinking of a lower gear ratio?
i heard these are great gearxs for the 6spd
it will definately help get you spinning off the line
the only way it will help is if you have traction that can handle that kind of torque "increase"
i plan to do it once i get some money
also, may i suggest the 4.11s?
these are like 9 pinion 37 rear insteand of the usual 10 pinion, 40 ring gears
they are a lot stronger since they have less teeth
somebody else might be able to chime in with where to get them
Old Sep 2, 2004 | 06:16 PM
BiGGinZ's Avatar
They will help if you can hook up. I was in another members car m6 that has 4:10's and you could tell it help the power range but he had some no tread tires and he was just spinning through 3rd. and finally getting traction in 4th. But if you can get traction they will help for sure.
Old Sep 2, 2004 | 06:22 PM
99_Z_155's Avatar
that sounds sweet, i wouldnt mash it like that, i would take it to the slip limit, tires cost too much. but i do alot of driving, im a student about 120 miles from home and i drive there sometimes. i just wanted to know the highway mannerisms and lost fuel mileage.
Old Sep 2, 2004 | 06:28 PM
JoeliusZ28's Avatar
I turn 2k rpms at 70...excellent highway mileage (27 or so?)
Old Sep 2, 2004 | 06:56 PM
99_Z_155's Avatar
Wow, not too many more than i do now, about 18 or 1900. if a lose to another f bod by about .5 to a car length, would this give me the edge?
Old Sep 2, 2004 | 07:37 PM
Z95m6's Avatar
gears would be fun but if you hook it with the stock 10bolt say bye bye to it.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jan 31, 2015 07:29 PM
tds1213
Nov 27, 2014 12:55 PM
Jul 4, 2005 05:00 PM
YellowTransAm350
Mar 2, 2003 03:38 PM
