tranny help, po753 and brown, bubbly fluid
Old Sep 18, 2004 | 06:40 PM
rckrzy1's Avatar
Ok it's my kids s10 but it has a 4l60e and the p0573 is the solenoid a fault and
then found fluid bubbly and brown, BUT it only has 68K on this 1996 and 4 banger engine. Any ideas what's up?
Old Sep 19, 2004 | 06:39 PM
rckrzy1's Avatar
Re: tranny help, po753 and brown, bubbly fluid
well, I dropped the pan, pulled both shift solenoids, both ohm out
good and both worked fine at 7.5 volts as advertised, replaced
filter and fluid, codes gone, shifts fine, all OK, So I give as to
why it was coding, but it had 2-3 gears only before, now it's
fine, fluid not bubbly, flushed it out again and hope it stays
fixed. I also checked wiring between trans and pcm.
Old Sep 19, 2004 | 06:52 PM
mark896's Avatar
Adam,
Hello, I'm in Burleson currently. Anyways, I think you'd probably get more help with this inside the Drivetrain forum. They're used to this type of thing over there.
I wish I could help but I know nothing about trannies, and even less about automatic trannies.
Good luck
Formula Steve
Sep 19, 2023 08:31 AM
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 02:44 PM
drt
Sep 27, 2015 04:39 PM
Daluchman1974
Sep 11, 2015 06:12 AM
