Pinion Seal Leak
Old Sep 10, 2004 | 03:17 PM
FireHawk409's Avatar
Pinion Seal Leak
I installed GMmotive 4.11 gears and a new stock diff,since then my pinion seal has been leaking. I got a mechanic to change the pinion seal, and then it started leaking again. Has anyone else had this problem? Is it a common problem? What could have went wrong during the 4.11 install to maybe cause this?
Omar
Old Sep 11, 2004 | 02:58 AM
smoknta's Avatar
Re: Pinion Seal Leak
I had the same problem. I put in 3.73 gears and after I had a pinion seal leak. I went and bought another and installed the new one. This time covering it with a good bearing grease for added sealing. It has not leaked since.
Old Sep 11, 2004 | 11:08 AM
Ya i did a search and it seems that you have to tighten it down really reallyt tight. I talked to my mechanic who did it and he said he tightened but maybe not enough. Hopefully thats the problem.
pimpen1024
Aug 19, 2015 08:36 PM
Noct
Jul 14, 2015 01:18 AM
camaro02DK
Jul 5, 2015 09:24 AM
Aug 11, 2002 02:24 PM
RobertoZ28
Jun 16, 2002 02:04 PM
