I think I put clutch in wrong.
Old Sep 9, 2004 | 04:15 AM
cmking26's Avatar
I just got done with engine rebuild and put clutch and tranny back in. I can switch through the gears without pressing clutch??? The motor is still not all together so its not running yet. When I put clutch disk in I put the side that sticks out toward the flywheel, so the flat side of disk was touching presure plate. Is that right? Or is fork maybe not on right? This is my first manual car so Im new at this.
Old Sep 9, 2004 | 07:53 AM
Chris Wilson's Avatar
Re: I think I put clutch in wrong.
in a manual transmission car you will be able to shifter gears without the clutch if the car is not running.
Old Sep 9, 2004 | 08:28 AM
JordonMusser's Avatar
West South Central Moderator / Special Guest
hell, you can drive around and shift with out a clutch if you want to.
Old Sep 9, 2004 | 06:48 PM
cmking26's Avatar
when I put the clutch disk in I put the flat side of disk toward pressure plate is that right? Anyone have a diagram.
Old Sep 9, 2004 | 06:56 PM
Z95m6's Avatar
it sounds like you put it in right.
BPS
9
Mar 5, 2015 10:51 PM
eazyZ
Mar 1, 2015 07:12 AM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
ModdedNerd
Dec 18, 2014 10:52 PM
