Need Help with Freshly Rebuilt A4!!!
Old Sep 8, 2004 | 03:16 PM
IT-Guy's Avatar
Question Need Help with Freshly Rebuilt A4!!!
I just rebuilt my A4 and installed it, but I have no drive in any range. I was meticulous about the rebuild and it all came apart and together with no problems. I was certain it would work with no problems.
However, it didn't. I have tested the line pressure and it is good (55 psi at idle, 180 psi when revved). When I engage it into drive, reverse, or any other gear, I get no response. I dropped the pan and removed the valve body looking for any signs of a problem, but found nothing. The manual valve body linkage was connected, the check ball in place, and all electronics connected. I have also tested the solenoids, which all tested fine.
Is there anyone out there with tranny experience that can help? I am stumped. Please Help Someone!!! What do I check next.
Thanks,
Christian
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
DelSoto
Sep 19, 2015 05:31 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
blaze309
Sep 8, 2015 05:27 PM
