Annoying!!!
Old Sep 5, 2004 | 10:31 AM
camaroz28_97's Avatar
Annoying!!!
After doing my rear swap (12 bolt) I have had a really loud rattle. Today I decided to investigate it and think I found the problem. There is a lot of play in the control arm bolts. As u can see form the pictures the bolt is tight in the rear but very loose in the control arm. Its like this on both sides. I’m broke right now so new ones isn’t an option. What else can I do to fix the problem???
http://www.wyland.cz28.com/0012.htm
Old Sep 5, 2004 | 10:52 AM
teke184's Avatar
Re: Annoying!!!
linky no worky
can't yoou just torque them down more? maybe buy some sturdyer bolts and really put a hurtin on em
Old Sep 5, 2004 | 10:56 PM
brandboZ28's Avatar
Re: Annoying!!!
Looks like the bolts are worn down in the middle due to the extra play of the control arms. I would think that the only fix would be to replace them. They cant be too expensive.
Old Sep 6, 2004 | 01:52 AM
Need4Camaro's Avatar
Re: Annoying!!!
Hey, "Lowes Knows" man ...
Old Sep 6, 2004 | 09:21 AM
brandboZ28's Avatar
Re: Annoying!!!
Either that or "Ace is the Place"
Honestly, look in the classifieds and see if someone is parting out a f-body and see if you can pick up a pair from them. Either that or find out what size they are and hit up the hardware store. If you end up going the hardware store route, make sure the bolts are grade 8, dont use no sissy bolts or youll be back in the same boat in no time at all. Good luck with it man!
Old Sep 6, 2004 | 02:54 PM
Re: Annoying!!!
well the bolts are tight in the rear. Where it goes through the control arm is very loose. a bigger bolt will not fit through the rear.
Old Sep 6, 2004 | 09:39 PM
brandboZ28's Avatar
Re: Annoying!!!
Oh, I guess I didnt understand the original post.
Sounds like its time for some new bushings to me.
Old Sep 8, 2004 | 10:19 AM
Re: Annoying!!!
part # and where to get them please
Old Sep 8, 2004 | 01:09 PM
brandboZ28's Avatar
Re: Annoying!!!
http://www.thunderracing.com/catalog...&vid=4&pcid=92
Down towards the bottom. PN 47-7-226. Plus, theyre on sale right now
cristian1311
Sep 12, 2015 08:16 PM
Boss002
Jul 24, 2015 10:47 AM
thorflynn15
Middle Atlantic
May 13, 2015 06:08 AM
Z28Freak86
Apr 28, 2015 10:35 PM
ad356
Apr 16, 2015 05:38 PM
