Tranny Fluid
Tranny Fluid
When reading trans temp through the pcm on a scanner. where is the sensor and how accurate is this? reason for asking is because if the sensor is on the pressure port then it would be reading higher temps
The factory schematics show the sensor is a simple thermistor. On that basis, you can't tie another gauge into the ciruit, because it would alter the resistance on the circuit, and the temperature is based on the variable resistance of the sensor.
