One wheel peel...broken/worn LSD?
Old Feb 4, 2008 | 06:56 PM
Gtpguy's Avatar
Whenever I do a burnout, it will only leave 1 patch from my passenger side tire. Never from both and NEVER EVER from the driver side. Is the stock LSD worn out? If I jack up the rear and rotate a tire, both spin, but on the street it's obvious that isn't working. I understand how LSDs operate.
Now, the passenger rear spring was cut months ago to accomodate a body lean I had from when the original stock Kmember was badly bent by the previous owner. Basically to have the car sit level. The kmember was replaced but the rear spring wasn't. The car still sits level today so I never felt like replacing something that wasn't "Broken". Could a cut spring on the passenger side cause a one-wheel-peel to happen? More traction due to more weight being put on a weaker spring?
Old Feb 4, 2008 | 07:30 PM
greenmachinedriver's Avatar
sounds like a worn lsd unit, the clutches dont last forever.
Old Feb 4, 2008 | 08:17 PM
sn8ke eatr's Avatar
when you jack up the car and spin one tire, the other is spinning in the same direction correct? if its spinning backwards it means you just dont have a posi.
it sounds like a worn out limited slip to me, how many miles you got on your car? thats prob. the problem
Old Feb 4, 2008 | 11:04 PM
Gtpguy's Avatar
Thanks guys. I might as well do gears when the time comes.
Old Feb 8, 2008 | 08:40 PM
Gtpguy's Avatar
You know what, I jacked the car up today to remove the wheels and sure enough I spun one and the opposite tire moved the opposite direction. So I don't have POSI or it's broken?
Old Feb 9, 2008 | 12:46 AM
LSWHO's Avatar
search for a stock 6 speed rear for CHEAP....... That's what I did.
force10
Aug 10, 2015 08:30 AM
30th Anniv Z28
Aug 1, 2015 10:39 AM
240ssLs3
Jul 13, 2015 05:06 PM
Slayer
Jul 4, 2015 03:06 PM
jasonduaine
Jun 4, 2015 09:29 AM
