Are stock LT1 flywheels nodular or cast iron?
Bump.
Same question, anyone want to confirm the answer?
For the Powergrip HD clutch it says the following:
"The Ram Powergrip HD clutch sets are designed for use with RAM billet steel or factory nodular iron (explosion-resistant) flywheels."
So that is why I need to know.
They say that because the Powergrip HD bites hard. A high RPM clutch dump with a hard biting clutch can blow your flywheel apart. So unless you plan on doing that, the stocker works just fine. If you plan on moderate track use, then upgrade the flywheel to a stronger unit.
Bump.
Brandon Wittmer
Dec 3, 2014 09:28 PM
FryZss
Sep 3, 2002 03:52 PM
