4L60E swap to 700R4
Old Mar 23, 2008 | 03:48 PM
Shawn94Z28's Avatar
4L60E swap to 700R4
Hello everyone.I'm new to this...I've got an 94 Z28 with the 4L60E.The trans went bad and i was wondering what excactly would it take to swap it for an 700R4?As far as wiring and computer set-up would go?As from what i've heard and read its a direct bolt in.Any help would be greatly appreciated...Thanks
Old Mar 23, 2008 | 05:12 PM
A 4L60E is basically an electronically controlled 700R4. You would not gain any real advantage from a 700R4 and you would have to add linkage for kickdown and deal with any other complications.
Old Mar 23, 2008 | 09:55 PM
12SCNDZ's Avatar
You'd have to find a '93 throttle body, because you'll need a pivot for a TV cable, you'll need a '93 TV cable, and bracket. You'll need a suitable governor. If your car has stock gearing, a '93 governor for that ratio should work. You'll have to find a way to wire up the electrical for the lock-up function.
Let's start with...Why are you considering this swap?
Frank
CPT
Old Mar 23, 2008 | 11:26 PM
Performabuilt's Avatar
Supporting Vendor
I would have to ask the same question, The 700r4 is not stronger than the 60e They are essentially the same unit ones hydraulically controlled and the other is electronically controlled and I would prefer the ladder for tunability reasons
Old Mar 24, 2008 | 12:03 AM
GreasyB's Avatar
Thats what I was thinking.
Old Mar 24, 2008 | 12:18 AM
Supporting Vendor
I have run into this a few times on different forums for some reason some people think the 700r4 is stronger , Its the same trans! So I ask why ?
Old Mar 24, 2008 | 12:29 PM
Shawn94Z28's Avatar
Thanks guys for the info,,,,looking for the faq's and opinions for this
Old Mar 24, 2008 | 05:04 PM
Supporting Vendor
Well the Fact is there no advantage to be had with this swap . Its not a difficult swap byany means. You would have to as mentioned set up a place on the throttle body for a TV cable to hook up other than that its pretty straight forward, You would have to setup work out something for lockup to work. But If your thinking better performance or durability there is no gain , In fact its a step backwards IMO
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
gtstriker86
Aug 26, 2015 10:56 PM
Cam's maro
Aug 11, 2015 07:45 AM
