Aluminum Flywheels (LT1)
Old Feb 26, 2008 | 06:37 PM
95mysticta's Avatar
Hey all, i just wanted to know what are the pros and cons to getting an aluminum flywheel? I got my eyes on a Fidanza right now i just want to know what im up against.
Thanks,
Matt
Old Feb 26, 2008 | 09:16 PM
Green96Z's Avatar
Well, since most aftermarket flywheels are neutrally balanced, if you have the stock rotating assembly (which is externally balanced) then you cannot use it.
Old Feb 26, 2008 | 09:28 PM
95PoloVert's Avatar
Take the Fidanza to a machine shop along with your current FW and they'll match-balance it. I think I paid ~$35 to get it done.
Old Feb 26, 2008 | 11:43 PM
95LT1conv's Avatar
I installed a Fidanza on my LT1 right out of the box with no issues.
Old Feb 27, 2008 | 06:22 AM
PoorMan's Avatar
I have a Ram Al flywheel. Was balanced out of the box. Pics in sig showing weights. Drives fine imo. I believe it weighs alittle more than the other Al flywheels. I went with this one since it is thicker and less likely to warp. Never heard anything bad about either though.
Old Feb 27, 2008 | 11:33 AM
95mysticta's Avatar
well i know the flywheel was in the previous owners car for less than a season before he was hit and parted the car. knowing thats its been in a previous car i would assume its been balanced?
Old Feb 27, 2008 | 08:16 PM
95PoloVert's Avatar
Yeah...to HIS rotating assembly.
Now you need to get it balanced to YOUR rotating assembly.
Since your current FW is already balanced correctly for your engine, you just need to locate a shop that can match-balance them, and you're good-to-go.
The Fidanza comes zero-balanced out of the box. The guys running them successfully on LT1s *without* match-balancing fall into 2 basic categories:
a. Those who happened to have a rotating assembly that was pretty close to zero-balanced.
b. Those who are experiencing some additional driveline vibration that may not even be noticeable.
Old Feb 27, 2008 | 08:44 PM
95mysticta's Avatar
Well im converting mine over from a4-m6 so the stock flywheel i have is matched to another engine as is the aluminum flywheel i just picked up.
Im confused on what to do
Old Feb 28, 2008 | 05:54 PM
95PoloVert's Avatar
If you have the original flexplate, that's what you would balance to in this case.
If you *don't* have that flexplate, then you'd better hope that your rotating assembly is pretty close to zero-balanced.
Old Feb 29, 2008 | 02:13 PM
95mysticta's Avatar
yeah ill have the flexplate to work with... getting flywheels balanced can you go to pretty much any transmission shop and be able to do it or do i have to find a specialty shop?
sorry im new to manual world this will be my first stick car i dont know much about the tech stuff.
Old Feb 29, 2008 | 02:16 PM
dangalla's Avatar
funny, thats not what they told me when i called them. to zero you remove the weight that is bolted to one side
Old Mar 1, 2008 | 12:05 PM
95PoloVert's Avatar
When I picked up mine, the weight came in a separate bag, but regardless the only time you'd ever use it is if you were match-balancing an externally balanced engine, like the LT1.
95mysticta, you'll just deliver the old FW, & the Fidanza (with weight, whether or not it's already mounted) to your shop and they'll take care of it for you.
Old Mar 1, 2008 | 12:19 PM
95PoloVert's Avatar
I used a local performance shop.
You asked about pros & cons of an aluminum FW...here's one of the better articles I've read on it: http://www.vortexbuicks-etc.com/spin_zone.htm
The entire article is worth reading, but "Item # 4: Measuring the Flywheel Effect" specifically discusses the FW topic.
Old May 23, 2008 | 12:39 PM
khojo16's Avatar
hey sorry to bring up this thread again, but i just swapped a 383 LT1 into my firebird and picked up a new Fidanza aluminum flywheel in the process, and im wondering if the weight is that little black part held on to the back by three bolts, or if that part needs to be on there for zero-balance.
here is a pic of front and back:
Old May 23, 2008 | 02:20 PM
Green96Z's Avatar
Call Fidanza and ask them. They will know for sure.
