Th400 Where,what And Who...
Old Mar 20, 2008 | 02:56 PM
jammer94's Avatar
hey guys i wanted to go th400 and wanted to know what i would need to modify in order ot make it work on my car, does anyone make a boltin crossmember for the th400? also who is a well known reputable builder of these trannies or can i go with just an off the shelf TCI superstreetfighter trannies which are capable of 800hp i wanted ot go with reverse manual valve body and with a transbrake.
what is needed in order to make our stock driveshafts work with the th400 i figure it would be longer but will i need a different slip yoke?
any help would be greatly apprecaited.
Old Mar 20, 2008 | 03:13 PM
JakeRobb's Avatar
Super Moderator
I believe BMR makes a bolt-in TH400 crossmember.
What are your plans for the car? Are you sure you want to give up your overdrive? CPT could build your 4L60E to withstand 800+hp, and it would probably cost you less than that TCI would.
Old Mar 20, 2008 | 03:30 PM
jammer94's Avatar
yeah but theres no brake on CPT's 4l60e thats why
Old Mar 20, 2008 | 04:55 PM
Can we assume you are asking about one of your B-Bodys?
The TH400 requires a TH400 slip-yoke.
Old Mar 20, 2008 | 09:57 PM
jammer94's Avatar
thats cool is there a place i can get one from a part number or something.
and yes for one of my b-bodys the roadmaster.
Old Mar 20, 2008 | 10:26 PM
Any driveshaft shop can get you a TH400 slip yoke. Here's the one I have:
http://www.markwilliams.com/detail.aspx?ID=295
I have a "slightly used" (less than a dozen passes) Mark Williams 3" chrome moly DS with that yoke, and a solid 1350 diff-end yoke. I only removed it because I needed a much shorter one when I added the Gear Vendor unit. If you are interested, and you can figure the length you need, let me know (via PM or e-mail), and I will check to see if it matches the length of the one I have available.
Old Mar 20, 2008 | 11:44 PM
jammer94's Avatar
thanks for the info Injuneer but i wish the DS would work for my application but i think the f-bodys shaft is like 2' short of what i need. now i have to come up on a slip yoke..i hope it uses the same 1350 joints that are on my stock shaft.
Old Mar 21, 2008 | 07:21 AM
rskrause's Avatar
Moderator
Not trying to be a wiseass, but if you need a TH400, you need something better than a stock driveshaft.
Rich
Old Mar 21, 2008 | 09:48 AM
jammer94's Avatar
i wouldnt see why my bud running mid 10's in his b-body is running a stock shaft but w/e.
Old Mar 22, 2008 | 09:37 AM
revtime's Avatar
All he is saying is why put a marginal DS in when if you really need a TH400 then you really need a decent DS.
I have a TH400 and a Strange 12 bolt. Connecting the 2 is a Dennys Nitrous ready DS. If you have never expierenced a DS failure at speed then trust me when I say you don't ever want too.
I am a cheap bastard but I learned the hard way that the driveline is not the place to cheap out.
Old Mar 22, 2008 | 10:46 AM
jammer94's Avatar
i will be making a custom Alum DS regardless as it is a better price for me then just making a regular steel one.
Old Mar 23, 2008 | 06:15 AM
rskrause's Avatar
Moderator
Get a steel DS. An Al shaft has no place on a drag car (which is what I assume you are building).
Rich
Old Mar 23, 2008 | 10:35 PM
I thought carbon fiber was the hot setup... and the 3.8" HD ACPT CF DS I bought failed. Now I use chrome moly. Buddy of mine with a blown 383 twisted an LPE 3.5" aluminum DS into a pretzel at less than 750 flywheel HP. He switched to chrome moly.
w/e
Old Mar 23, 2008 | 10:42 PM
mdacton's Avatar
w/e
any serious racer is going to have steel. Its the only dependable/safe option IMO.
I don't think b-bodies come with 1350 joints (maybe a 1 ton truck) they probly have a 1310.
you can get a good slip yoke from a truck driveline shop, they are made by strange engineering. about $170 or more. with 1350 joints.
Not sure why anyone who "needs" a 400 would consider an of the shelf el cheapo converter or a POS TCI trans. They make good parts but the units are turds.
Frank at CPT may be willing to build you a 400, You could buy one from Rossler or coan or someone depending on what you need.
BTW you have a few people looking for you in the seller feedback claiming they have been scammed, just a heads up
RUENUF
Mar 13, 2016 03:37 PM
james007moore
Jan 1, 2016 01:14 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
detroitmuscle
Jul 31, 2015 04:21 AM
