Shift Problems Help???
Old Jan 30, 2008 | 11:33 AM
DEEZ-Z28's Avatar
I own a 95 Z28 Lt1 with Automatic trans. Heres the problem. My shifter when put into park stays in reverse. Actually here is how the shift lays out
P = Reverse (no back up lights and car can be shut off and restarted in gear)
R = Reverse with backup lights car will not shut off and restart.
N = Neutral when shifting out of Reverse Stays in Drive when shifting out of drive.
OD = Drive with overdrive but shift mechanism doesnt prevent shifting into neutral. Shifter isnt locking in OD it can be moved to neautral position and stays in OD
D = 3 rd gear (will dowshift to 3rd but doesnt lock.)
2 = 2nd gear ( will shift into 2nd gear but doesnt lock)
Is this a shift cable problem or something else. Any help will be appriciated.
Old Jan 30, 2008 | 01:19 PM
Check the shift cable at the transmission (especially, to see if the bracket has come loose). Or it may need adjustment.
Old Jan 30, 2008 | 05:45 PM
DEEZ-Z28's Avatar
Loose bolt on the cable bracket!!! Works fine now except for that intermittent work/not work of the Park Shift selenoid. Any ideas on this Shoebox?
Magenta_Hearts
Mar 30, 2015 09:42 PM
BigWil
Mar 29, 2015 12:24 PM
jb4xx
Feb 2, 2015 10:00 PM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
