viper transmission?
Old Mar 11, 2008 | 10:45 AM
Burnt_Bizcut00's Avatar
viper transmission?
i'm going to be doing an A4 to t56 swap soon and can pick up a tranny out of a srt-10 cheap. from what i hear the shifter is the only difference in the srt-10 tranny and the viper tranny. will this transmisson work with a few pieces switched out, or is it better to go with a camaro t56? thanks
Old Mar 11, 2008 | 10:52 AM
What car are you trying to do the swap in..... that will determine what you can and can't use??? The obvious differences are the input shaft lenght and clutch designs between the LT1 and LS1 T56's, and that assumes you are talking about a 4th Gen.... or maybe its a 3rd Gen????
Why not add a "signature" with basic info about your car - year, model, engine, tranny and any major mods. That way people can answer your questions more accurately.
Old Mar 11, 2008 | 06:34 PM
87zjeff's Avatar
you will have to swap a lot of stuff to get the srt/viper tranny to work in your application. the input shaft is different(splines and pilot size) plus the bell pattern is different so you would need a bell housing. plus you will need a yoke and universal since the splines on the output shaft are different. plus you would prolly need a special crossmember. this is assuming you are talking about a camaro or firebird.
Old Mar 12, 2008 | 12:10 AM
the swap is happening in a 2000 z28, but it sounds like a PITA so i'll just look for a camaro tranny. thanks
Old Mar 12, 2008 | 02:54 PM
You can get beefed up LS1 T56's from a couple sources.
football4life
Oct 4, 2015 07:48 AM
4586
Sep 27, 2015 01:55 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
