700R4 TCC Hookup
Old Feb 24, 2008 | 05:49 PM
PWR SHFT's Avatar
700R4 TCC Hookup
I am hooking up a race prepped 700R and need to hook up a manual switch to control lockup when on the street. Does anyone have a schematic on how to wire this up? This is a race only setup so I am not concerned about automatic TCC activation. I just want a switch on the stick so I can control it at will.
Thanks in advance!
Old Feb 26, 2008 | 11:50 AM
PWR SHFT's Avatar
Ttt
Old Mar 2, 2008 | 12:08 PM
PWR SHFT's Avatar
ttt
Old Mar 2, 2008 | 04:54 PM
12SCNDZ's Avatar
If it's a "race only car", why didn't you do a non lock-up conversion? you'll never need lock-up in a drag car. We NEVER advise manual lock-up switches, because most people forget to lock them, and a 700 needs lock-up in 4th gear to keep the 3-4 clutches alive. Whoever built your transmission should have wired it, internally, to control the lock-up apply. We usually wire them through a 4th gear switch, and a 4-3 pulse switch, on the valve body. We also suggest the customer wire it through a brake light switch, and a low vacuum switch. The LV switch is needed because YOU NEVER WANT LOCK-UP AT WOT!
If your car was originally a 4L60E car the wiring would be simple...providing the transmission is wired right internally, using the "A" and "D" terminals at the case connector. Did you specify it was a swap transmission when you had it built?
Frank
CPT
Old Mar 2, 2008 | 08:31 PM
PWR SHFT's Avatar
Honestly Frank, the transmission was already built when I bought it. It came out of an 89 IROC and was built with a reverse pattern manual valve body. I got it for $800 from a guy up in MD that fbody central used to use. It came out of his personal car. My car was originally an M6. It is going to be 90% strip and about 10% street. Its the 10% street that I want the lockup for. I know I run the risk of burning it up if it does not lock up in 4th. I don't have the highest confidence in the trans so if I blow it up, I'll be knocking on your door. In the mean time, I can handle manually locking it up. Where do I get the connector for the trans and how do I wire it up? I am open to all suggestions. I am on a severly tight budget.
Thanks,
Chris
Jake Bialke
Sep 24, 2015 11:31 AM
92_RS_305
Sep 8, 2015 07:47 PM
Cam's maro
Aug 11, 2015 07:45 AM
jimmybandana
Mar 22, 2015 07:44 PM
90 Z28SS
3rd Gen / L98 Engine Tech
Aug 19, 2002 09:31 PM
