Clutch petal grinding?
Old Feb 17, 2008 | 03:54 PM
kgkern01's Avatar
Just put in a new trans, go to start it and has a little trouble, but starts, and the trans is loud. Try to push in the clutch and when within 1/3 of the floor, it starts grinding bad. when pedal released, revs fine. Can't put pedal to floor to put in gear because of this. What's goin on here?
Old Feb 17, 2008 | 06:32 PM
Green96Z's Avatar
Did you replace the clutch at all? What kind of sound is the tranny making, a whining or grinding? Does the car try to move at all in neutral? Make sure your clutch fork is seated properly on both the tranny and the T/O bearing.
Old Feb 18, 2008 | 07:37 AM
kgkern01's Avatar
Pulled the slave, the clutch fork is hitting the PP. It feels a little loose when on TO bearing still. Can the fork be removed without pulling trans again?
Old Feb 18, 2008 | 01:57 PM
Green96Z's Avatar
It's normal for it to feel loose. As long as the t-stud is torqued down all they way (did you use loctite on that bolt?), it's fine. The fork will move around a little on there, the slave cylinder puts the pressure on it.
Old Feb 18, 2008 | 03:57 PM
kgkern01's Avatar
I definitely tightened the bolt down enough. I wonder if maybe I just didn't have the fork 100% all the way on? I'll check here in a min.
Old Feb 19, 2008 | 04:57 AM
kgkern01's Avatar
Yeah it was on all the way. Went ahead and took it back off the trans. Bent the spring back down so it would stay tight, grinded a tad off the fork where it rubbed and ground the T down about a mm or 2. Hope that works?
Old Feb 20, 2008 | 08:42 AM
kgkern01's Avatar
Red face
Problem solved! Finally drove it to work for the first time in 3 months. Going from a stock clutch/flywheel and stock MN6 to a dual friction clutch w/alum flywheel and M29 is def different.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
