gm 93-02 10 bolt
Old Mar 2, 2008 | 08:31 PM
max_ta's Avatar
gm 93-02 10 bolt
can you weld the axle tubes to the center section
Old Mar 2, 2008 | 11:30 PM
GreasyB's Avatar
I dont see why not. But I am kind of confused as to why or what the heck you are talking about.
Old Mar 3, 2008 | 09:46 AM
How will you prevent the heat from warping the axle tube and causing misalignment?
The tube-to-center-section connection is not the weak point. Its the small ring gear diameter.
Old Mar 3, 2008 | 11:33 AM
white97T/A's Avatar
FWIW, that is exactly what a shop did in this magazine article.
http://www.highperformancepontiac.co...ferential.html
Old Mar 3, 2008 | 01:18 PM
And when then got all done, they had spent $1,700 and ended up with a rear axle that was good for 425rwHP on an automatic, and not recommended for a manual trans.
Part 2 of the article should be posted as well.
http://www.highperformancepontiac.co...ild/index.html
Decide what you want to do with your Pontiac, and then make an informed decision on whether the 10-bolt can survive with your driving interests and style. For drag racing applications pushing up to 425 rwhp with an automatic transmission, the 10-bolt might perform great, whereas an identically equipped six-speed might not fare as well. If you intend to drag race on a regular basis, seriously consider a 12-bolt. For Birds looking to run 8s and 9s, a Ford 9-inch or even a Dana 60 will serve you well.
Old Mar 3, 2008 | 01:28 PM
white97T/A's Avatar
Thats an understatement... my 10-bolt is currently broken for the 4th time since I have owned my car. I am letting it sit there broken until I can get a 12-bolt. I wouldn't recommend anyone to waste a dime messing with a 10-bolt.
Old Mar 3, 2008 | 07:53 PM
max_ta's Avatar
dig this shade tree made http://www.tnfbody.com/forum/showthread.php?t=7235
and thanks for the replys Injuneer
Old Mar 4, 2008 | 06:18 AM
AL SS590 M6's Avatar
Moderator
By quickly tacking it turn 180° tack it turn 90° tack it turn 180° tack. Then tack other tube. Then weld it up 1/2'' welds at a time using the same rotation methods.
The tubes are pressed in rather firmly so if it's done right it doesn't pull from heat. And yes I was a welder at work for a few years.
Old Mar 4, 2008 | 05:48 PM
max_ta's Avatar
exactly Al
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
